4K Gov for 24 valve
Re:4K Gov for 24 valve
dodgeboy:<br><br>The 24 valve engines do not use the 4K Gov Spring<br>Kit because their fuel pump (VP-44) is electronically<br>controlled. To be able to have and use the 4K gov<br>spring kit you would need to install a P7100 Fuel<br>Pump on your 24 valve engine. <br><br>---------<br>John_P
[quote author=dodgeboy59td link=board=7;threadid=14002;start=0#131639 date=1051238515]<br>Do they make any 4 k gov kits for the 24 valve? Wes<br>[/quote]<br><br>you would have to go from 32bit to 64bit<br><br>
No.<br><br>The ecm stops full load fueling at 3200.<br><br>Max high idle RPM is 3500.<br><br>with bigger injectors it is possible to go to 3500...but there is very little power up there
[quote author=nevrenufhp link=board=7;threadid=14002;start=0#132343 date=1051415193]<br>Sounds like the need for a 24V with a Piers Stooopid pump to me!
<br>[/quote]<br><br>don't remind me... :'( <br><br>
<br><br>
[quote author=Jim Fulmer link=board=7;threadid=14002;start=0#132372 date=1051422369]<br>Piers Stooopid pump <br><br>Got one, there nice!<br>[/quote]<br><br> :'(<br><br><br>Jim, GOTO BED, YOUR MAKING ME JEALOUS!!!
I have a question for those with or considering a P pump conversion. At what rpm do the stock valves hit the pistons and what do you consider a safe operating rpm with regard to valve piston contact? Inquiring minds want to know! Larry
[quote author=Roger rodbolt link=board=7;threadid=14002;start=0#132971 date=1051571012]<br>I have a question for those with or considering a P pump conversion. At what rpm do the stock valves hit the pistons and what do you consider a safe operating rpm with regard to valve piston contact? Inquiring minds want to know! Larry
<br>[/quote]<br><br><br>Larry,<br><br>I have never run my truck over redline before I had it up at Piers' shop last month. I had kissed 3 pistons with only 10k miles on the truck. Only one of the intake valves touched on each piston and it was the same one on all three. I went with a bigger gasket this time and when the $$ is available I'll go to the heavier valve springs. They are $25/each.<br><br>Nathan
