3600 Dd Help!!
Old 09-02-2007, 09:03 PM
35" 05''s Avatar
3600 dd Help!!
I've only had my SB DD 3600 for a year maybe. It has been nothing but trouble for me. Granite it has held very well for everything I've done and a lot of the problems just come from the annoying fact that it's not sprung hub. When I take off with a little gas as I let off it makes a noticeable squeek sound. Tonight I did a little burnout not half as big as a lot that I've seen and when I got done the pedal was down to the floor and would not come back for a few seconds when I then worked it through the gears. I did not ride the clutch, I let it go and tapped the brakes a tad just to slow the truck down a little but did not hold them. I have heard of this with single disks but dual? Anybody help please. I do not want to spend 5k on clutches in 1 year or I would have gotten an auto.
Old 09-02-2007, 09:37 PM
SmokinDodge12V's Avatar
Call Peter at SBC he is a stand up guy and stands behind his products.
Old 09-02-2007, 10:32 PM
PourinDiesel's Avatar
Originally Posted by 35" 05'
Tonight I did a little burnout not half as big as a lot that I've seen and when I got done the pedal was down to the floor and would not come back for a few seconds when I then worked it through the gears. I did not ride the clutch, I let it go and tapped the brakes a tad just to slow the truck down a little but did not hold them. I have heard of this with single disks but dual? .
Repeat after me:
Intentional clutch slippage will destroy any clutch in short order.
Ever use an angle grinder? Well its the same deal...it gets hot and you see sparks...next thing your putting a new wheel on it....same deal with clutches...wear them out and guess what...time to rebuild!
Old 09-03-2007, 07:04 AM
UnrulyNFS's Avatar
Yup, might be time for a rebuild.
Do you have the hydraulic upgrade? Make sure your good on fluid if you do.
Old 09-03-2007, 08:01 AM
35" 05''s Avatar
Originally Posted by PourinDiesel
Repeat after me:
It was grabbing the whole time is the thing. tires were spinning. did not touch the peddal.
Old 09-03-2007, 08:23 AM
35" 05''s Avatar
does a rebuild include buying a whole new clutch or just pads? What is the usual $$ for that?
Old 09-03-2007, 08:29 AM
Chet,
Not trying to speak for Peter here or anything but typically rebuilds are much less than retail price for a current SBC DD owner.
On a rebuild every wear item is replaced (basically ends up being like new again).
Old 09-03-2007, 08:39 AM
35" 05''s Avatar
Thanks bud. I guess I'll call the doctor tomorrow. Anyone wanna lend a fella a tanny jack?
Old 09-03-2007, 10:16 AM
Here is the one I bought. Great jack and works great. The seller has also taken care of me on one little issue I had with it:
http://cgi.ebay.com/ebaymotors/TRans...spagenameZWDVW
Old 09-03-2007, 10:23 AM
oil_burner's Avatar
hey chet, I gota tranny jack you can use.
chris
Old 09-03-2007, 01:59 PM
wap
wap's Avatar
When you talk to Peter you may as well see about gettin a 3850lb pressure plate to go with it. I would not think this would be in the rebuild kit but it may save you from doin this again.
Old 09-03-2007, 09:54 PM
35" 05''s Avatar
Yeah I was planning on getting that. I dont mind the upgrade as much, it's just gettin help to change it.
Old 09-03-2007, 10:11 PM
wap
wap's Avatar
You really only need one extra set of hands to change it and that is for the removal and reintall of the flywheel. It would also help when reintallin the trans too.
Just make sure you got a good tranny jack and take your time. It aint rocket science, just kinda labor intensive.
Plus you got all the knowledge you could need from this site if you do have any questions.
Old 09-03-2007, 11:06 PM
claymeis's Avatar
My clutch just started to do the squek thing also. I wonder what this could be?
Old 09-04-2007, 01:14 AM
Its normal with in town driving.
Quick Reply: 3600 Dd Help!!
