3500 Rear Axle - Frame Question
Old Feb 11, 2004 | 11:43 PM
y-knot's Avatar
I don't think you wasted anything. The 8.5 inches, is it the vertical mounting you are referring too? I suspect it is, cause that is what they wanted when I installed my air bags. Be a little more specific , and gee don't wuss out so fast, there is always a way.
Old Feb 12, 2004 | 12:09 AM
Haulin_in_Dixie's Avatar
I think that you will find that the axle is narrower. The pickup uses the inside tire at the same location as a single wheel and adds the outer tire outside the pickup body. Shorter is stiffer and handles more weight.
Old Feb 12, 2004 | 09:31 AM
1ST CUMNZ's Avatar
WHAT HAULING IN DIXIE SAID
Old Feb 14, 2004 | 02:48 AM
Rattletrap1's Avatar
You should be able to return the airbags. Some really do have fitment issues. You may find that Timbren's fit as they replace the bump stop.
TWX
Jun 27, 2013 12:51 PM
Tyheethan
Feb 25, 2009 12:12 PM
gts95
Aug 27, 2007 10:13 AM
95black2615
Dec 20, 2006 06:37 PM
ptgarcia
Sep 12, 2006 06:04 PM
