33 or 35 tires
Old Feb 26, 2008 | 08:26 PM
06er's Avatar
33 or 35 tires
im gonna take my 5inch lift off my 01 and put a leveling kit on in the next week or two any suggestions on which one is the best and do you guys have any pics of leveled trucks with 33 or 35 tires so i can decide what size i wanna go with
Old Feb 26, 2008 | 08:33 PM
Jason Foster's Avatar
35 with just a leveling kit will be tight. 33 will work just fine. Why are you removing the 5 inch suspension lift? Most people are installing this setup.
Old Feb 26, 2008 | 08:36 PM
schaef_12's Avatar
get your spacers from hell bent steel.
Old Feb 26, 2008 | 08:47 PM
merr6267's Avatar
Here's mine with 33-ish tires.
These are Nitto Terra Grapplers 325/60-18
They are about 33" diameter and they rub just a little on the fender.
I definitely would not go bigger. I like them the way they are, but I'm even thinking that when I get new ones to go a little smaller . . .
And don't think that I don't like big tires . . .
I just feel like something that is mostly driven on the street just plain works better without the hugeness.
I just remembered about a friend who put 35's on his superduty and regretted it later . . .
Take care,
Phill
Old Feb 26, 2008 | 08:49 PM
06er's Avatar
urrently only getting 15 mpg hopenig that if i would go with the level kit and drop from 35s to 33s i could gain a couple of mpg or is it possiable to get 20mpg with the 5 inch lift and 35s
Old Feb 26, 2008 | 08:54 PM
What's up with the golf cart dude. We're talkin BIG tires. Those 33's are very wide. Goodyear Wrangler 305/70R17 looks nice and don't rub with the right backspacing on your rims.
Old Feb 26, 2008 | 08:58 PM
06er's Avatar
thinking 305/70 16 cooper discover stt
Old Feb 26, 2008 | 09:13 PM
Those are 32.8 inches tall. Should work fine and look good. Very aggressive lugs.
Old Feb 26, 2008 | 09:34 PM
wurkenman's Avatar
Here are my 33's
Old Feb 27, 2008 | 12:45 AM
1BAD4X4's Avatar
I'm running 315s on a stock wheel AND suspension with no issues. I get the tires rubbing on the control arms at full lock. My set-up is fine for a truck that spends most its time on the paved roads.
Old Feb 27, 2008 | 01:06 AM
Bjans's Avatar
i have 35's with a leveling kit and love it! i wouldnt go smaller
Old Feb 27, 2008 | 07:24 AM
fiveology's Avatar
Depends on what gear ratio you have. If you have 4.10s I would stick with 35s. If you have 3.55s like I do 33s are a better choice. I am currently rinning 315/75/16s, seriously considering going to a 285/75/16 for my next set.
Old Feb 27, 2008 | 08:12 AM
olddodgetruck's Avatar
i have a 3'' spacer with an add a leaf in the back and i had a set of 33 on it and they were to small i just put a set of 315/70-17s on it they are on 3rd gen wheels. the 315s have plenty of clearence even with my plow squating the front down. but i also have 4.10
Old Feb 27, 2008 | 10:09 AM
fmxr47's Avatar
theres mine on34" buckshots before my body lift, they rub on the control arms a bit, no fender rub at all
MSquare's Avatar
Exactly!
I love the looks of the 35's, but with 3.55......no way.
