2nd gen Tanks
Old 07-01-2008, 04:52 PM
stang's Avatar
2nd gen Tanks
Who knows the diff between the 3rd gen and 2nd gen fuel tank? does the 2nd gen have a high vent or does it need the the vent mod? can you grav. feed from an aux fuel cell on a 2nd gen tank without it leaking?
Old 07-01-2008, 04:57 PM
OldDodgeOwner's Avatar
I haven't heard of a vent mod for 2nd gens. On mine, if I let it completely fill up with the gravity feed, it'll leak out of the top, but seems like it only leaks when moving. I think it's splashing out of the rollover vent, but don't know for sure. I just installed an electric valve so I can open and close it from the cab.
Old 07-01-2008, 05:23 PM
crabbelle's Avatar
mine will flow out of the filler neck with the cap off.
Old 07-02-2008, 12:04 PM
kawi600's Avatar
yikes! You need some sort of top-off mechanism like an airtight aux tank that needs fluid level in the main tank to go low before it can exchange fuel. Or even maybe an electric valve from an outfit like pollak. then you can fill the main tank from the cab with a switch.
The vent in the gas cap can still leak a bit of fuel. The rollover valve in the filler neck should help keep the big splashes down.
Old 07-02-2008, 02:25 PM
stang's Avatar
my 05 never leaked a drop it was grav. feed, two tanks full to the brim
BRUISER
02-02-2015 11:25 AM
rwhite1
10-27-2011 08:06 AM
77machomopar
07-15-2009 04:56 AM
ocsurf16
09-25-2006 10:36 AM
Quick Reply: 2nd gen Tanks
