23 psi at idle!!!
Old Apr 20, 2006 | 04:46 PM
Rauschbo's Avatar
23 psi at idle!!!
TROUBLE!
I installed a FASS a few months ago, and just got the FP gauge hooked up; It is reading 23+ psi at idle - this CANNOT be good for my vp, how can I fix this?
Thx / Rauschbo
Old Apr 20, 2006 | 05:48 PM
BigBlue's Avatar
Call up DPP or who ever you bought it from and tell them that you want a different pressure spring.
Old Apr 20, 2006 | 07:58 PM
Rauschbo's Avatar
They gave me a 3-day minimum delivery....
In the interim, I am thinking about removing the return line ball valve and cutting a wee bit off of the spring to cause the valve to open sooner.... - shave a bit at a time and test it...? I think I recall reading about someone trying this?
Old Apr 20, 2006 | 09:45 PM
dslchk_cowgirl's Avatar
23 is good at idle (according to how my hubby explained it to me). Mine runs 21 at idle and still doing good. What's it running at WOT? That when you have to worry, is when it starts dropping to really low.
Old Apr 20, 2006 | 11:25 PM
AAmeeting's Avatar
It will come down. Mine use to idle at 20+. Now its 17 and on a stock motor I can bring it to 12 pounds. I change the filter and cleaned the water separator and no difference. I wouldnt give it a second thought.
Old Apr 20, 2006 | 11:30 PM
oestreich84's Avatar
I don't have a FASS, but I am running 21-24 at idle. Full throttle, won't go below 18-19. I have had zero hard starts or any other problems.
Old Apr 21, 2006 | 12:29 AM
Sea Bass's Avatar
I wouldn't worry. When I first put mine on I was seeing 25psi at idle. After a few days it settled down to 19.5psi at idle. I can only pull it down 2psi at wot though.
Give it a few days.
Do you have any hard starting issues?
Doug
Old Apr 21, 2006 | 08:14 AM
Rauschbo's Avatar
Starts like a champ, 1/2 a revolution, usually;
I'm worried about overpressurizing the VP diaphragm, I believe that this will kill it as surely as too litttle pressure....
I've had the FASS on since early Jan (?), and have maybe 250 miles on it since;
Is it everyone's belief that:
1) It's okay to run at these high pressures
2) The pump will "wear in" and get down to the 18-20 psi range?
Old Apr 21, 2006 | 07:18 PM
AAmeeting's Avatar
Yupe.
Old Apr 22, 2006 | 01:26 AM
Sea Bass's Avatar
250 miles in the last 4 1/2 months? Saves on fuel I guess
I wouldn't worry. Did DPP say this is too high?
Old Apr 22, 2006 | 10:02 AM
Rauschbo's Avatar
....been driving the ricer...at 37mgp combined!
My dealer is ordering me a new spring, I spoke with someone at DPP, he told me that I could cut a bit off of the return check-ball spring....he didn't sound too concerned, the VP apparently has it's own overpressure valve?
Old Apr 22, 2006 | 10:37 AM
high country's Avatar
My 30lb gauge has been stuck on the needle for 50k plus miles.....you should be fine
Old Apr 22, 2006 | 01:01 PM
Rauschbo's Avatar
Okay, NOW it gets weird: Under hard acceleration, it went from 23 psi to......30 psi? I thought the pressure should drop under increased demand?
Under not-quite WOT, I am reading about 19 psi...that seems pretty normal....
Rauschbo
Old Apr 22, 2006 | 01:08 PM
inline6power's Avatar
i have the BD pusher pump kit and i run at 34 at idle and 26 at WOT. i havent had one prob with my setup and i have had it one for about 8 months. all i no is after 3 VP44s, i would much rather have hight presure than very low presure.
Old Apr 22, 2006 | 06:04 PM
Rauschbo's Avatar
Note: The 19 psi I see at not-quite-WOT is BOOST pressure, the FP is ~30 psi....
