1998 will not start
Old Aug 28, 2009 | 08:50 AM
myersb's Avatar
1998 will not start
Went to the store came back out now it will not start. No error codes,has fuel but will not start.Need help
Old Aug 29, 2009 | 06:07 PM
BigIron70's Avatar
Cummins Guru
12 valve or 24 valve?
Old Aug 30, 2009 | 04:37 AM
dozer12216's Avatar
My internet eye tells me something just died. I assume you entered this in 2nd gen because that's what it is. Fill out signature would help. I futher assume you mean it cranks fine, just no startie. Check lift pump pressure and flow to assure have fuel to IP. How much did you say you wanted to spend? Cause you're looking like a good case for IP failure. Most sensor failures will at least give a fault code to some degree.
21dovehunt
Oct 7, 2015 08:35 PM
myersb
Aug 28, 2009 10:23 PM
nddeluca
Apr 23, 2008 09:03 AM
loosendend
Sep 4, 2006 12:01 PM
goldenmatt
Jul 27, 2005 12:25 AM
