1995 Ram 3500 Brakes
Old 05-22-2008, 05:50 PM
Robertschas's Avatar
Cool 1995 Ram 3500 Brakes
I really need help on this one as i am stopped in my tracks.
I put on new shoes, cylinders, calipers and rotor pads. Turned drums and rotors. put all back together and bled brakes...very little pedal, just like it was before. Adjusted rear shoes...same thing. Push hard on pedal and it will slowly go to the floor.
Put on new master cylinder and bled the master etc and wheels. Now it has same problem except now when i have to pump the pedal more than once, the brake pedal gets very hard and high and it won't stop. (Just as if it had air in the line, but it doesn't).
Main two issues here are:
1)Why does pedal slowly go to the floor and
2)Why is the pedal so hard and brakes won't hold truck?
Has anyone else ever had this probelm and how did you solve it?
Thanks for you help and have a good weekend. Chuck
Old 05-23-2008, 01:02 AM
prattman's Avatar
Check all your brake hoses front and rear. Have they ever been changed?
Old 05-23-2008, 09:51 AM
infidel's Avatar
Pedal slowly creeping down indicates a leak somewhere. It could be internal in the master or ABS unit where no fluid escapes the system.
Hard brakes that don't stop sounds like your vacuum assist isn't doing it's job.
Old 05-23-2008, 08:03 PM
Thanks all for the help. I managed to tweak some hoses and adjust rear shoes and did a test run and it worked fine now.
Thanks, Chuck
Old 05-25-2008, 09:48 PM
dozer12216's Avatar
Next time, do job in segments. IE, do front and test, then do rear. Get a service manual.
hiofficr
06-03-2009 01:41 PM
nilezy
10-25-2008 10:28 AM
Robertschas
08-19-2006 02:34 AM
Robertschas
08-02-2006 01:07 PM
wildcargo
11-29-2005 04:20 AM
Quick Reply: 1995 Ram 3500 Brakes
