150 Oil
I think it is Exxon Sparton.
SPARTAN EP
150
ISO Viscosity Grade 150 Viscosity, ASTM D 445
cSt @ 40ēC 150
cSt @ 100ēC 15.8
Viscosity Index, ASTM D 2270 98
Pour Point, ēC, ASTM D 97 -27
Flash Point, ēC, ASTM D 92 245
Density @15.6 ēC, ASTM D 4052, kg/l 0.89
Timken OK Load, ASTM D 2782, LB 65
4-Ball EP test, ASTM D 2783:
Weld Load, kg 250
Load Wear Index, kgf 48
FZG Scuffing, DIN 51534, A/8.3/90, Fail Stage 12+
Copper Strip Corrosion, ASTM D 130, 3 hrs @ 100ēC 1B
Rust protection, ASTM D 665, Sea Water Pass
Foam Test, ASTM D 892, Seq II, Tendency/Stability, ml/ml 0/0
Demulsibility, ASTM D 1401, Time to 3ml emulsion, minutes:
@ 54ēC -
@ 82ēC 30
http://www.exxon.com/USA-English/Lub...NEPGearOil.asp
SPARTAN EP
150
cSt @ 40ēC 150
cSt @ 100ēC 15.8
Weld Load, kg 250
@ 54ēC -
@ 82ēC 30
Actual spec on the oil:
The MSDS shows that it is Morlina Oil 150 with:
CAS# Concentration Ingredients
Mixture 100% weight Heavy duty turbine oil
64742-54-7 90-99% Hydrotreated heavy paraffinic distillate
Mixture 1-2% Proprietary additives
Thoughts? It is a take or leave deal tomorrow.
CrashCade
Dec 3, 2008 07:58 AM
dodgediesel
26
Nov 2, 2008 12:20 PM
curts99
Feb 14, 2008 12:09 AM
heavyJ
Oct 25, 2007 09:08 AM
Ramtuff06
Aug 21, 2007 06:21 AM
