12er shifting funny
Old Sep 13, 2009 | 05:39 PM
quadstar's Avatar
12er shifting funny
Just had a new auto trans put in my old 12er. Truck runs and shifts fine if I drive it normal. Taking off at about 1/4 to 1/2 throttle, truck goes thru the gears perfectly. Lock up works fine. If I drive the truck hard- and have fun, truck won't shift unless I let up on the pedal. I have to left off well past 1/2 throttle so the truck will shift. First to second is perfect under full throttle. Its the shift from 2nd to 3rd that the truck won't make under full throttle, or almost full throttle.
Old Sep 13, 2009 | 11:23 PM
Fueling around's Avatar
Check the throttle cable
http://www.dodgeram.org/tech/transmi..._lever_adj.htm
Old Sep 14, 2009 | 08:35 PM
quadstar's Avatar
shift
hey thanks for heads up. Thats a pretty simple fix. I won't get to try it until the morning, but the alignment was off. Once I was able to figure out how to work the button, it was easy. I had the local trans shop scratching there heads. They kept saying its the valve body or its internal. Just wasn't adding up. The trans is brand new, works fine at low speed, but when you hammer on it, all of a sudden the internals are bad- yeah B.S> . Its so hard to find a good mechanic with a brain, that won't rape a guy on price, and really has a full understanding of things
quadstar
Jul 1, 2009 07:25 AM
Brendan
Oct 17, 2007 11:12 AM
wtmtnterror
Apr 21, 2006 08:58 PM
Lil Red
May 21, 2004 11:30 PM
