06 transfer case front output flange bolts
Old 03-15-2011, 08:20 AM
BigDiesels's Avatar
Help Please. I've searched all over, and can't find the bolt size for the front driveshaft to the front output flange from the T'case. When my front shaft failed, that rear yoke and the output flange stayed together, and I took it all into the driveshaft shop, so I lost them.
I've tried all the free issue bolts around that size, both metric and standard, and the best I can see is that it is a 10 mm, but what pitch?
I know the fronts are 8 mm, and hex heads are replacing the torx, but what bolt for the rear mount of the front shaft?
Thanks.
Old 03-15-2011, 12:45 PM
farmerger's Avatar
Thanks.
I can look for you tonight, mine are lying on my tool chest right now.
Old 03-15-2011, 03:43 PM
jumper's Avatar
Check out this thread: https://www.dieseltruckresource.com/...e-t286794.html. He says they're M8x1.25x35 and he used 12.9 grade ones. Wait, that was for the connection to the front pinon flange. Sorry, but maybe they're the same.
Old 03-15-2011, 04:05 PM
BigDiesels's Avatar
Farmerger, if you could check that would be great. Jumper, I have the front flange under control, and the rear is definitely NOT the same. The Dodge parts girl I deal with said they are 0.473-14 x 1.25"? This doesn't make sense, unless she had a little dyslexia and meant 0.437, which would be a standard 7/16" (grade 8) bolt. I thought I tried that one already, but I'm going to try again. Dodge wants $7.60 / bolt for their part number. Pretty expensive if it is a simple 7/16" NC...
Old 03-15-2011, 06:29 PM
05 CTD2500's Avatar
I had mine sitting around too so here it is..
NC 7/16-14
1.25" long with a .115" thick washer
Old 03-16-2011, 06:13 PM
farmerger's Avatar
NC 7/16-14
You beat me to it, yup that's what I found to. To the OP, what transfer case do you have? Mines the NV273. May be different bolts for different cases.
Old 03-17-2011, 07:19 AM
BigDiesels's Avatar
Thanks guys... yes, I have the NV273 as well, and my flange did turn out to be 7/16" NC. The holes just weren't tapped quite enough to run the bolts in easily. Anyway, don't buy these bolts from Dodge @ $7 / ea!
RuralCruiser007
03-22-2010 12:03 AM
Free89W350
07-23-2009 12:27 AM
rschaer
08-06-2007 09:02 PM
DEC
09-29-2003 09:47 AM
Quick Reply: 06 transfer case front output flange bolts
