04.5 mid range power loss
Old Aug 27, 2006 | 09:24 AM
CajunBoy's Avatar
I have an 2004.5 and among other problems, its getting hard to start, I have to turn it over quite a bit before it starts. I have right at 75000 miles on it, I have a quad std box on it, it also feels, when you take off, it has a flat spot in the acceleration around the midrange. don't really know what rpm's, but it acts like i am either losing fuel or boost on it. Even with the quad off, it still does it. Any help would be greatly appreciated.
Old Aug 27, 2006 | 09:29 AM
PourinDiesel's Avatar
Do you have a supply pump like a FASS to keep inlet pressure up?
Old Aug 27, 2006 | 07:24 PM
donhov's Avatar
As above probably lift pump on the way out if not already gone. Also could have damaged the injector pump (CP3). A third item to check is the comon rail pressure relief valve. Guess if you don't already have one I would suggest a fuel pressure gague to see what is going on. Would/could be any/all of the above.
Old Aug 27, 2006 | 08:04 PM
judge88's Avatar
check yor fuel pressure and relief valve. its one one of those two. probaly lift pump if i had to guess
Old Aug 28, 2006 | 06:22 PM
XLR8R's Avatar
Running a fuel box w/o a fuel pressure gauge is like boost-braking w/o a tranny temp gauge... it's just a matter of time
Old Aug 28, 2006 | 07:46 PM
Spooler's Avatar
That is what mine did when the LP was going. Check for codes also. When was the last time you changed your fuel filter?
Welcome to DTR. Fill out your signature so we know what kind of truck you have and mods if any.
MTC
Oct 10, 2011 03:06 PM
92cummisw350le
Dec 9, 2007 05:13 PM
lugnutt4449
Jun 22, 2006 11:05 PM
Iron City
Jan 25, 2006 10:46 AM
