Another gauge picture thread
Old Aug 6, 2008 | 03:07 PM
  #31
BMH95's Avatar
There's space or it, but it needs to be as low as possible. That area would add to the pillar blind spot that is so bad on these trucks.
Old Aug 6, 2008 | 11:58 PM
  #32
txpig's Avatar
Originally Posted by Extrema2
Here's my ISSPRO EV Gauges in an SRT10 A Piller mount and 3 gauge dash mounted pod...
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Looks good!!! Looks like you need to buy your truck a fresh tank of green gold. Haha
Old Nov 20, 2009 | 01:41 PM
  #33
cromulius's Avatar
Question for you guys about install. I was just wanting to run a power line from the batery for the gauges and split it to a couple of switches for powering them up and lighting them up. Maybe a dimmer for the lights. My reasoning for this is the dealer can never say I messed the factory harness up by tapping. Thoughts?
Old Nov 20, 2009 | 05:02 PM
  #34
Lil Dog's Avatar
Originally Posted by infulleffect
The S.P.A's do look nice and clean in there...does anyone have any pics of the windshield mount pod?
I have the windshield mount system on my 08.. These are the Isspro EV2's.
Old Nov 23, 2009 | 08:37 AM
  #35
Jagsfan811's Avatar
they look good.. i like them
Old Nov 27, 2009 | 10:26 AM
  #36
cromulius's Avatar
There is someting about those dash pods that just look cheesy. I think maybe just three autometer single pods mounted up there might be cool. I really like the dipricol mech fuel pressure, egt, trans half sweep because they all have the redline just like the factory gauges. The dipricol boost by it self on the pillar looks good since it does not have the redline.
Old Feb 14, 2010 | 05:55 PM
  #37
jimmyjhilljr's Avatar
ok back to the level kit. what all did you have to trim to fit those 37s under a stock height truck with just a 2.5" level?
Old Apr 11, 2010 | 11:18 PM
  #38
EverydayDiesel's Avatar
Originally Posted by GMScott
Here's the mount I used for my Edge Insight. I wanted to mount it above the overhead but couldn't get it to fit the overhead mount I bought for it. I like it high and close enough so that I can see it without having to put my glasses on while driving.
why couldnt you get it to fit? im just about to buy the over head for my insight
Old Apr 12, 2010 | 10:06 AM
  #39
Shorts's Avatar
This configuration is my first choice for getting three gauges in. My concern is about the weight of the pod/gauges and also running the wire. How difficult is that? Did you have to use brackets to support the pod? Where does the wire run?
Old Apr 12, 2010 | 10:27 AM
  #40
Lil Dog's Avatar
The EV2 gauges are all electronic so its only wires to run for the boost, pyro and TTemp. Tubing wouldn't be that hard either. The pod has a couple of tabs that hook under the headliner and 2 very strong 3M velcro pads that connect to the windshield.
Once you bundle the wires together its not that hard to install. I basically had most of it terminated before I put them in. The pyro lead just reached I didn't even trim it off. Wrapped the wires to keep a nice tight bundle and it just fits in behind the headliner and down the pillar.
My only concern is when I have to replace the windshield and getting the same type of velcro to replace it. Other than that its nice if you decide to change your mounting system, its non-destructive to the interior. Also leaving it black it seems totally stealth against the windshield, can't even tell you have gauges from the outside..
Old Apr 12, 2010 | 01:31 PM
  #41
2171CTD's Avatar
Heres my setup. Trans, EGT, FP on pillar and boost on column
Old Apr 12, 2010 | 02:53 PM
  #42
Shorts's Avatar
Ok, thanks for the details.
Old May 23, 2010 | 11:14 PM
  #43
Crazy_Farmer's Avatar
My contribution. Just did this install over the weekend. Pretty straight forward and easy. fuel pressure on the column, and pyro/boost/trans temp on the dash. Very happy with it, ordered everything from diesel manor, picked it up a couple weeks ago at the shipping office but didnt have time till this week to finish the install
Still have to do all the fuel plumbing in the engine bay though.
Old May 24, 2010 | 12:03 AM
  #44
GMScott's Avatar
Sorry I'm so late on this, must've missed it.
The overhead mount did not fit the Insight. It was made for the Edge Juice as the wire connector on the Insight is placed differently from the Juice and keeps the Insight from fully fitting into the mount. I tried to "customize" the mount to fit it but the way the mount is molded it did not work.
That was some time ago when the Insight was still pretty new. Maybe they have an overhead mount made specifically for the Insight now, I don't know.
Hope that helps and ya didn't spend the $$ for an overhead mount that won't work!!
Old May 24, 2010 | 07:14 AM
  #45
05 dodge's Avatar
