1 ton front axle camber problem
Old Jun 13, 2007 | 12:32 AM
mullishacrew's Avatar
on my 1993 ram 250 with the cummins turbo diesel and 1 ton front axle, i am having a odd problem with the camber angle..in the drive way looking at the truck the camber angle is way off (negative camber) and then i put it in the garage and back it out again and all of a sudden the tires are straight again....and it does this on and off one day it can be out real bad then the next it is completely straight....to fix this do i take the 4 bolts off the top of the axle end where the pivot bolt is and tighten that while it's in the straight postion or what do i do?
Old Jun 13, 2007 | 12:35 AM
90firstgen's Avatar
Sounds like you need some ball joints and or tie rod ends.
Old Jun 13, 2007 | 12:54 AM
MikeThomas's Avatar
Is it a 2wd or 4wd? Either way it sounds serious. I would check it out soon.
Old Jun 13, 2007 | 07:15 AM
2stroke's Avatar
king pins are worn out.
Old Jun 14, 2007 | 02:40 AM
90dodge's Avatar
kig pins
Its your King Pins for sure. I had the same problem. Find a good 4x4 shop, or suspension shop.
Bob
TX_Diesel
Aug 21, 2011 09:40 PM
cletus
Jul 6, 2011 11:31 AM
Free89W350
Mar 24, 2008 08:04 PM
Big J
Dec 12, 2007 07:52 PM
dma251
Jun 19, 2003 04:17 AM
