wow - Overflow valve
Old May 11, 2009 | 01:31 PM
BIG&BAD's Avatar
i just replace my overflow valve and man did that wake my truck up
it has not ran like this in years
i would get white smoke going 75mph on the highway with very little power
now the thing pulls to 90 in a heartbeat
I just wanted to thank Infidel
for the little how to guide
Bruce
Old May 11, 2009 | 06:31 PM
infidel's Avatar
You're welcome.
My bet is the overflow valve is the most common part that wears out on a 12 valve. Important part too.
Good to install a fuel pressure gauge or to regularly replace the valve.
There's a guy on ebay who sells Bosch overflow valves for $30.
Old May 13, 2009 | 04:06 PM
bigfatricky's Avatar
Can you link me to the how to guide from Bill?
Thanks!
Old May 13, 2009 | 06:36 PM
infidel's Avatar
Easy one wrench (19mm or 3/4") 5 minute job.
First stuff a rag under the OF valve so you don't loose the sealing washers.
Take the old one out, put the new one in.
Occasionally the old valve hits the intake. Don't bend the line to get it out.
Instead screw it back in then file or grind the notch in the intake so it comes all the way out.
Object in lower left is the oil fill
Old May 14, 2009 | 04:57 AM
cmac's Avatar
so its just the one nut/bolt under the retainer? are there any tell tale signs that this needs to be replaced?
Old May 14, 2009 | 09:10 AM
rynojr4644's Avatar
what if the retainer is missing off of the org one that is on the truck now?
Old May 14, 2009 | 09:43 AM
1-5-3-6-2-4's Avatar
my original OF valve had a broken spring in it when I got the engine. that why my FP was under 15 at idle. this was just a stocker '95 engine. dont take the small nut off the overflowvalve thats where the spring and ball are. pull the whole thing out. there 2 copper seal rings one on each side of the line. don't loose them is what infidel is talking about with putting a rag underneath before you pull the valve.
Old May 14, 2009 | 09:48 AM
infidel's Avatar
If it were missing fuel would be spraying all over the place.
You have the new design valve that is one piece that you can't take apart, no retainer.
Symptoms of low fuel pressure most often caused by a bad OF valve are:
Lack of power
Poor fuel mileage
Sputtering or missing at high rpms or under load
White smoke
Old May 14, 2009 | 02:17 PM
rynojr4644's Avatar
ya I was looking on ebay and the one guy has a picture and it looks like mine I have a 98 12V. Thanks
Old May 15, 2009 | 08:26 AM
blackimpala's Avatar
I ordered the one off ebay the day I read this post 05/11/2K9 got it in the mail 05/14/2k9. That was fast!
Floyd
Old May 15, 2009 | 12:37 PM
cmac's Avatar
Floyd
could you pm me the link to the ebay listing? thanks
Old May 15, 2009 | 06:57 PM
infidel's Avatar
Originally Posted by cmac
could you pm me or e-mail me (cjm28@hotmail.com) the link to the ebay listing? thanks
eBay Cummins Overflow Valve
Old May 15, 2009 | 08:59 PM
cmac's Avatar
thank you............... now ordered!!
Old May 16, 2009 | 12:08 PM
HelenaTDI's Avatar
Sweet bought one myself. Guy on ebay still has 4 left.
http://cgi.ebay.com/ebaymotors/ws/eB...m=250425345078
Old May 18, 2009 | 04:43 PM
cheapskate's Avatar
infidel helps me again without his knowing. thanx. i ordered one from the e-bay link on friday, it got here today (monday). i just put it in, and so far so good. more power, less smoke, smoother idle.
