Where to drill hole for brakesmart wire's
I've all ready used the clutch rod cover plate for all my guage stuff. Just wondering what all you guy's have done. A pic would be great. :D
Cant you get another hole in the clutch plate cover? 'Course, the brakesmart needs a fairly large hole, so you might be in a bind. I've never used anything but that cover....
I've got duall coax cable. pyro wires, boost tube, & brake smart wires all going thru the rubber grommet under the clutch pedal.
I have a stick, so I used the rubber boot that blocks the hole for the auto shift linkage, but I do have one suggestion that might be helpful...
You can use a pick to remove the wires from the plastic plug, so you can slip the wires through a smaller hole. Just be careful/gentle with them, and of course be sure they go back in the same position. |
https://www.dieseltruckresource.com/..._Entry-med.jpg |
Hey,,great idea's guy's. I knew someone would come up with something. Thank's.
