What primer to paint aluminum camper?
Old 05-23-2007, 11:26 PM
wcbcruzer's Avatar
I'm going to be painting our camper. The current paint is all faded and peeling. The body of the camper is aluminum so that's good. What primer/paint should I use so the paint sticks well? I guess I could go ahead and sand all the old paint off, but I really don't feel like it. It would be better if I could just sand the parts that need to be sanded, then air spray new paint on the existing paint. I'm not going for a showroom look here. Just something that'll make the camper look nicer than it is now.
Old 05-24-2007, 10:10 AM
Oilguy's Avatar
Get a steam cleaner and blast it clean... then let it dry good and sand what you need to sand smooth with 400gr>>> Then you can scotchbrite the whole thing and spray on a good sealer and then shoot it.
Old 06-03-2007, 05:32 PM
truk's Avatar
they make a special converter for alum so the paint will stick. if you want the paint job to last strip it all off or you will stand a chance of the old paint peeling after the new is on and loseing it all. if you use a self ecthing prime it will do the trick for you .it will stick real nice and paint will stick to it . ive used it on bread trucks alotnever had one peel yet.just my 2 cents matt
Old 06-03-2007, 05:45 PM
wcbcruzer's Avatar
Thanks Matt. Is there any self-etching prime brand/type you recommend?
Old 06-03-2007, 06:10 PM
annabelle's Avatar
I second the water cleaner. You can also add acid or sand to the water for additional abasiveness
Old 06-04-2007, 08:36 PM
truk's Avatar
just go to any car paint store they can get you what you need.good luck ! put up some pics of before and after matt
Metal Twister
21
01-11-2013 06:17 PM
jimbo486
06-24-2011 08:22 PM
jefe4x4
07-31-2010 08:28 PM
Bigsmoke3500
05-28-2008 03:32 PM
Quick Reply: What primer to paint aluminum camper?
