Truck got warm towing 4 first time????
Old Apr 30, 2009 | 12:49 PM
Stormin_Norman's Avatar
My stock 02 will push EGT's in the 1250 range pulling my 32' trailer, so I would get some gauges. As long as I keep the EGT's in the 1150 range it will pull hills all day and not get hot.
I also use some engine cleaner and pressure washer about once a year to clean the radiator around the puke bottle.
Old Apr 30, 2009 | 04:45 PM
RAF's Avatar
RAF
12,000 Thats a good typo...... Wasn't it 80 + degrees this weekend in that area?? Sounds about right to me
oops!!! little high hugh?
Old May 7, 2009 | 05:54 PM
5Oclock's Avatar
Originally Posted by WestTN
You need to remove the radiator and clean the backside of it. You cannot see the accumulated dirt an oil vapor while it is in the vehicle. Clean it and move the catch bottle off the front cover of the engine.
X2. If you can see oil and dirt it's bad. The puke bottle spray can plug the radiator without you even being able to see it. Best thing is to remove and clean it. That can save your motor. I learned this the $$$$$ way
Old May 7, 2009 | 07:05 PM
carl48's Avatar
the 01 was bad about what westtn said, be sure to move the tube or you will continue to have the problem
Old May 7, 2009 | 08:24 PM
w.tx iceman's Avatar
x2 put a rubber hose on there and route it underneath, that puke bottle will coat the back side of the radiator solid.
Old May 7, 2009 | 08:29 PM
babyjoe's Avatar
Thanks a million guys, I beleive I will put a longer hose on it, due to it does puke on the front cover aswell and makes it all nasty, I work for a large trucking company and we had acouple picky drivers who do that that on there old Detroits, Everyone always asked what that hose was hanging down there....
Old Jul 16, 2009 | 08:20 AM
n2moto's Avatar
8 year old radiator I'd replace it.
Old Jul 19, 2009 | 09:07 AM
Tobin's Avatar
I have cleaned a couple radiators off on trucks that were starting to get warm. You gotta pull the radiator out to clean it off good. You will be surprized how much crap gets in there.
Tobin
Old Jul 19, 2009 | 11:47 AM
Rednax's Avatar
Don't want to to, but . . thanks for the advice on pulling radiator. Sounds like good PM at next coolant change. (No problems and hope to keep it that way).
mtb1982
55
Jan 20, 2020 10:45 AM
klx650a2
Jul 22, 2008 06:47 PM
herb
Jul 18, 2008 08:25 AM
jc67
Introductions / New People
Feb 6, 2008 08:02 PM
k_butz
Feb 23, 2007 03:42 PM
