Tripple singles VS Dual tandem
Ok I'm gonna be in the market for a new trailer here in the near future and was wondering what the opinions were between 3 7000lb axles VS a dual tandem setup.
Please discuss
Please discuss
Tire wear VS inaccessibility? I would look at the type of driving I do with the trailer. If a lot of straight highway few turns then I would go triple axle, if tight turns are involved I would go dual tandem.
Same as stated above, Ive pulled boats numerous times that were on triple axle trailers and they do not like to turn sharp, especially backing into tight places. I think you can get a tandem dualled gooseneck that has a higher gross weight rating than something with triple singles... Do you want 8 tires on the road instead or 6? My next one will be a tandem dually.
Sound pretty unanimous Dual tandems is the way to go.
OK now the Legal part, being this will be for personal use will I be exempt from a CDL or will I need one because the gcvw will be 36,000. I will be hauling a loaded 1stgen puller with a slide in pickup camper over the neck of the trailer, on a select few occassions I will be pulling 2 loaded 1stgen pullers
Heres what we were thing about getting but in 35' flavor
http://www.kaufmantrailers.com/heavy...ELUXE-p25.html
On the legals if i recall correctly you will need a class a cdl even though its a privete use youll probly wamt to check with nebraska dmv first ..when i got stopped this summer that was brought up couse the fifth wheel i was running at the time was reg for 17k the chief of police was giving me some friendly advice
The only thing I can think triples would be good for is reducing the pin weight on the rear axle. If thats not an issue then doubles would be my pick. Also, if your pulling any trailer and grossing over 26,000 then you'll need a class A.
Jim O
