Are these EGT #'s normal ???
Old Oct 30, 2006 | 11:13 PM
svanni's Avatar
This weekend, I pulled the 5th from Phoenix to Sedona. EGT's ran about 1050-1100 with spikes up to 1250 & 1300. The highs came while pulling up 6% and 7% grades. Edge Juice/Attitude set at level 1. Is this normal for my setup ??? Should I be concerned ?
45 gal aux tank was full, 5th is approx 12k lbs dry, but probably closer to 14k lbs loaded.
Old Oct 31, 2006 | 01:28 AM
ptgarcia's Avatar
I'd say they are normal. I can hit 1100 degrees empty while hot rodding around.
Old Oct 31, 2006 | 01:36 AM
Jim Dynomite's Avatar
Sounds about right..............provided you have the pyro mounted before the turbo
...........Jim
Old Oct 31, 2006 | 05:20 PM
StrokeThisCTD's Avatar
As said already, perfectly normal pulling a heavy load. actually pretty cold pulling a big grade too.
Racing41
May 29, 2007 09:08 PM
t_george77
Nov 23, 2005 02:19 PM
Bugleboy
Mar 18, 2005 11:44 PM
swansong04
Feb 19, 2005 11:19 PM
northern puffer
Dec 23, 2003 09:00 PM
