Source For OEM 7way
I need a new seven way plug for my truck when I did the relo on it tonight I noticed its broke on the corner so it is only held on with three screws. Any one know were a person can get one that I don't have too cut any thing just plug it backing and screw it down and go
If you're talking about your factory plug,,,get it from the dealer. It's really cheap.
Okie dokie. I finally moved the thing out of the stupid spot it was put from the factory I got tired of riping plugs out which is probably why its broke. When I moved it out I cant believe it did not short it took me 2min of digging in the mud and crud too find the plug too get it out.
Dealer. I have several on the shelf that are part of full harness kits. Dealer would be faster though. I'm sure you can get the plug separate.
I just want the actual plug not the whole harness if I can't I will just jb weld a small line over the crack too keep the tab on.
I broke mine last summer, it was cheaper buyin it from the dealer than a generic one cost. $17.85 from the dealer.
