Is this a safety feature or what??
This has never happened to me before. I moved my dad's best friend into his new house last weekend. The trailer was fully loaded but was not overloaded. I had to back the trialer down a snake of a driveway and then push it through some mud to get it close to the house. This required using 4low and eventually I started digging in to the mud and had to stop before I got stuck. While I was positioning the trailer the engine temps started getting up to about 210-220 and the tranny temps were up to about 220-230 also (it was a real pain getting in there). Once the temps reached those levels my hi-idle was activated. Anytime I put the truck in neutral or park the idle jumped up to 1200. It was about 70 degrees out and I'm just wondering if that was normal. Actually I'm sure it is, I just never had it happen before.
Once we were done the truck and trailer came out of the mud easily. This truck is just the best!! By the way, I made more than enough $$$ to pay for the new Quad race box!!
I'm sure it's a safety feature in the engine computer to keep air/water moving through. Without water moving it's possible to get a hot spot and crack the head or the block IMHO. If you have a tranny fluid cooler in the radiator it was just heating the tranny fluid from the hot water in the radiator.
Edwin
Edwin
Originally posted by durasmack
i noticed the same thing with my 97.....
Not doubting that it happened, but still..
Well, I think the culprit may be a malfunctioning fan clutch. It appears that the engine idled up to get the coolant flowing since the fan was not cooling properly. Time for a new fan clutch and trans fluid........
lovin1stgens
Aug 31, 2018 09:49 PM
zek405
25
May 18, 2012 07:25 PM
