Trailer brake plug in
Old 12-27-2007, 11:51 AM
24v
24v's Avatar
I just bought an 06 2500 and pulled the brake box out of my 99 before I got rid of it. Is the plug in the same on the 99 and the 06 so I can use the same box/plug? Is the location of the plug under the dash in the same place as the 99?
Old 12-28-2007, 01:14 PM
RRAMctd's Avatar
well if your talking about brake control, then yes there is a set of wires labeled brake control under the dash if your truck came with tow package.
Old 12-28-2007, 02:03 PM
Hensley Ron's Avatar
I think he's trying to take the same plug from the 99 and put it in the '06. I wouldn't try it as the OEMs seem to take great pleasure in changing the brake controller wiring whenever the urge hits them. Cut the controller loose and re-wire it according the color code on the new truck. If you don't know which wires are for what on the controller, you can probably find it online. Tekonsha (Prodigy) is good about keeping that up. Or use the '99 owner's manual to figure which is which.
Old 12-29-2007, 10:08 AM
JuzPlaneKrazy's Avatar
Is it one of the newer style brake controllers like the Prodigy?? There is a plug under the dash that accepts the adapter plug from most brake boxs already. I would spend the money on a new brake box like the Prodigy and get the proper brake adapter plug to go with it. You'll spend about $150.00 maybe less. Well worth it to have a quality brake controller.
Old 12-30-2007, 12:18 PM
charger7022's Avatar
i have takin my brake controler out of my 05 and used it in my sisters 99 without a problem not sure about 06 but it worked for me
Old 01-02-2008, 10:15 AM
24v
24v's Avatar
It's a Tekonsha Voyager which has worked well for me over the past 8 years. I'm sure there are others out there that are better, but I don't need to upgrade the box, I just need to put it in the new truck.
Thanks guys.
Old 01-02-2008, 11:00 PM
Vinceg99's Avatar
Dodges brake wiring has been the same from like 1994 to current I havent heard of any changes?
Chief-295
01-13-2007 08:15 PM
Phil Howell
07-13-2006 12:08 PM
Dodgezilla
12-07-2004 09:41 PM
apache
12-05-2004 09:55 PM
Amish hauler
04-08-2004 07:07 PM
Quick Reply: Trailer brake plug in
