rear axel ratio
Old Jul 17, 2005 | 07:27 PM
jtskir222's Avatar
rear axel ratio
just picked up a 2500 2005 and the dealer says it has a 3.73 but on the sticker for axel ratio it has 11.50?? what does that mean??
my old dodge had 3.73 and this feels like it may be 4.10...
does anyone know what the 11.50 is?? i cant find anything on the web ..
thanks...
mark
Old Jul 17, 2005 | 07:31 PM
pind's Avatar
you have an 11.50 AAM rear axle, that is the size, not the ratio. Ratio should be on a tag on the rear axle housing
Old Jul 17, 2005 | 07:34 PM
jtskir222's Avatar
thanks for the quick answer i looked on the rear and there is no tag.. do you know of any other location for that info?
i checked the tags on the doors and no luck. my 2000 2500 had it also under the hood...
Old Jul 17, 2005 | 07:38 PM
pind's Avatar
you can call the dealer, and they will be able to tell you, generally using the last 6 of your VIN . This is also important when ordering stock replacement parts through the dealer network
good luck
Old Jul 17, 2005 | 07:39 PM
natstayl's Avatar
It's also on the label inside the glove compartment. ..The conventional glove compartment on the right, passenger side.
Nat
Old Jul 17, 2005 | 07:40 PM
jtskir222's Avatar
thanks guys will do!!!
Old Jul 18, 2005 | 03:53 AM
Casey Balvert's Avatar
Unless otherwise specified, the ratio is 3.73.
Casey
sullivad
13
Dec 18, 2006 08:47 AM
winkle
Nov 12, 2005 09:35 PM
JImbo1
Apr 9, 2003 07:46 AM
yz
Nov 25, 2002 06:04 PM
yomitch
Nov 22, 2002 12:11 AM
