Onan CCk 4.0 generator has 151 volt output
I need some help, my generator is putting out 151 volts. Could it be a voltage regulator?
Finding parts for thes old generators are hard, does anybody know a good resource to give me.
I use this place in Houston. They will talk to you and help you figure it out as best they can with not seeing it.
www.pplmotorhomes.com
Then Precision Equipment has a forum here www.perr.com it's not just Onan though.
YEP, correct. Check the frequency and slow it down to 60 and the voltage will probably be right on. Look for the small lever, held by a spring, that you can move and change the rpms. It will have an adjustment screw. Put your voltmeter on the output and slow that sucker down by adjusting the screw until the voltage reads 120 - - you will probably be right on 60 hertz.
Bob
Set it between 58 and 62 Hz. you can use a good DVM that counts frequency or the simplest way is to plug in an old synchronous clock the kind with hands and a motor, when the minuet hand goes around once and it the same as your digital watch the frequency is at 60 Hz and the engine is at 1800 RPM.
Check out this other site I am on, it is all about generators and old iron, there are some Onan techs on all of the time.
http://www.smokstak.com/forum/forumdisplay.php?f=6
There is a section just for Onan generators.
Jim
Jim
Dieseldude4x4
Jan 4, 2003 03:07 PM
