Installed Timbrens and love em
hey guys
i just installed a set of timbrens on my truck and love em my truck used to sit down bad ( looked like a lifted SD ford signaling aliens with the headlights pulling a emtpy little trailer) now its sits level with around 14,000lbs on a goose neck and it only costed $144 and took less than 30 minutes to install |
I've been thinking about these too rather then air bags....my 3500 will sag about 8-10" with a heavy loaded trailer
I know my spring pack is gettin weak so these along with a rebuilt spring pack should help !! |
they help out alot, now my dad and my brother want some for there trucks :)
I sure like mine, after my dad saw my Timbrens, he went out and bought a set for his gasser Chev.
steve |
I was also thinking about installing them,my problem is I tow a 30' fk Cardinal T/T when hooked up even with weight distribution I'm sitting on my overload springs.Does all your trucks have overload springs. Does theTimbren work with out hitting overload.
2500 ,98.5,24v,edge ez,k&n,4"magnaflow turbo back |
i dont have overloads on my truck :mad:
but i dont think that the timbrens would hit the overloads? man, since i put them on i have pull 3 loads one a test run with a f150 on a flatbed, and a load of cows weighing around 13,000 and now my truck is sitting on the timbrens, i guess its time to rearch my springs |
Sorry maybe I worded it wrong,What I ment is will my overload springs touch, before the timbrens touch and start working.
i don't have overloads on my truck,but when i installed my timbrens i did not like where they where coming into play in the suspension travel,so i called timbren directly and they told me what ones i needed and to call the dealer where i purchased them and to see if they had them,then i exchanged with the dealer.every thing is great now... :D ......all i had to exchange was the rubber spring,one bolt and it's off.the rest of the kit you keep on the truck.great product.here is where i purchased mine.
www.truckspring.com www.timbren.com |
I put Timbrens on my truck also.
I had to deal with Timbren directly. I told them the problem I was having. There only concern was getting it right for my application, and they did. I am a happy camper using Timbrens. Randy |
Originally posted by nubby3 Sorry maybe I worded it wrong,What I ment is will my overload springs touch, before the timbrens touch and start working. |
heres wheres i got mine $144 delivered http://stengelbros.com/
Have the Timbrens helped to reduce the static shock loading when traveling down the highways when crossing them little old cracks in the highway? Or are they just to help the truck sit level when loaded?
they helped with the shock your talking about
made my truck more stable with a load :) |
Where's everyone gettin those cheap price's all the links I checked the price was 200.00 or more ????
