How to charge camper battery while driving?
Old Mar 21, 2004 | 08:56 PM
SSV1761982's Avatar
Question How to charge camper battery while driving?
How can I charge the camper battery while driving without the chance of draining the main truck batteries when parked using the camper? Is there some way that I can charge but yet seperate the systems?
Thanks for any advice,
Dave Smith
Old Mar 21, 2004 | 09:02 PM
Dan Bromley's Avatar
hey dave.
you can check this site out it worked for me....DAN.
http://www.hellroaring.com/rv.htm
Old Mar 21, 2004 | 11:23 PM
Rare1's Avatar
Run your hot and ground wires to the camper battery. When you park, disconnect them at your hitch. Don't forget.
Old Mar 22, 2004 | 12:06 AM
Haulin_in_Dixie's Avatar
Two ways will work well. The isolator works fine or you can put a relay in the line fired off the ignition. That will work fine too. Isolator is best. Remember what an isolator is to start with. A wire comes from the main terminal of the alternator and goes through a diode to the rest of the system. An isolator just adds another wire through a diode so that the power cannot back up. I have some surplus 100 amp diodes and use them instead of an isolator. To make this work, disconnec the 12v wire from the plug, run a new wire from the isolator to the plug. Power will go out when the alternator is charging, but the batteries will not see this wire.
Old Mar 22, 2004 | 06:52 AM
pappyman's Avatar
I don't know if this would work for you.....but I have 2 batterys in my enclosed car hauler trailer that operate 2 winches and I need to keep them charged....so I have a Battery plug thats used on big rigs with electric tailgates it looks like the 7 way plug for lights and brakes but its made for battery power only....I have it wired to my truck batterys and can disconnect it when I dont need to charge my trailer batterys....I do have a 50 amp fuse in the line in case of a short so I dont burn up my truck wiring....if its not in use they make a special holder for these plugs to keep them from shorting out your trailer batterys
Old Mar 27, 2004 | 09:20 PM
SSV1761982's Avatar
Thumbs up Thanks going with an isolater
Thanks
Rancher99
Apr 18, 2011 09:46 AM
Travs94Ram
Jun 16, 2008 05:05 PM
Box5
34
May 18, 2007 08:26 PM
dieseldel
Sep 4, 2006 08:09 PM
puffmagicdiesel
Jul 7, 2006 02:34 PM
