Heaviest Load hauled?
Old Jul 5, 2007 | 06:16 PM
kycatpower's Avatar
6K Trailer and 8K + 8K Cat's = 22,000 lbs.
Old Jul 5, 2007 | 07:06 PM
clutch1's Avatar
17 5x6 very tight bales, on a 40' dual tandem with 2 15k axles, average wieght per bale was 1800, dew was heavy or something, after weighing i decided to make only one trip 33miles really needed to make three but i know my limits.
Old Jul 5, 2007 | 07:21 PM
cincydiesel's Avatar
I hauled 600 4x4x16's yellow pine and a unit (735) 1x4x8's for work for about 70 miles. I wieghed in at 33,400 gcw on a CAT scale. It took a while to get going but did great when I gained speed on the highway. It was a little nerve racking to see that G/N flex when I hit a pothole
Old Jul 5, 2007 | 07:33 PM
Homer S.'s Avatar
Three cords of green almond firewood on a 8600# GN dump trailer from cental valley into sierras. Heavy enough to only make 30-35 mph on the steeper parts of the highway.
Old Jul 5, 2007 | 07:48 PM
Nate-03 D's Avatar
Wow, you guys sure do tow some weight. Don't you have any concerns about stopping when your towing 20k+ pounds?
Old Jul 5, 2007 | 07:54 PM
Jordan5687's Avatar
Yeah, a little. Just make sure to go to the bathroom before hitting the road. I don't have an exhaust brake on my truck....yet. Hopefully pretty soon!
Old Jul 5, 2007 | 08:02 PM
Yeah, make darn sure you leave good distance between you and the next car and have good trailor brakes.
Old Jul 6, 2007 | 02:14 AM
Homer S.'s Avatar
With a good trailer and brake control you should be able to stop in the same distance as unloaded, as long as the trailer isn't over capacity.
Old Jul 6, 2007 | 02:28 AM
TexasCTD's Avatar
My loads are pretty light compared to some of these guys!
On my biggest load so far, I hauled a 15K + tractor about 400 miles. Stopped at the CAT Scales on the way and the weights were as follows.....5020 frt axle, 6200 rear axle, 15160 trailer axles......for a total GCVW of 26,380lbs.
And this is my current RV set up.....2004 Weekend Warrior FS2600 loaded up in this pic with 120 gallons of fresh water, 28 gallons of gasoline in the fueling station, 2 ATVs, generator, and bunch of other gear, etc. Front Axle 4700lbs, Rear Axle 5340lbs, and trailer axles 9440lbs for a GCVW of 19480 lbs.
Old Jul 6, 2007 | 04:19 AM
Goober's Avatar
I cant wait to run the scales in a couple of weeks. I know i wont be 26k like texasctd but i should be close to 20k.
Old Jul 6, 2007 | 06:35 AM
G1625S's Avatar
7.3 idi ferd. Prolly just shy of 20k gross. The Cummins loved it but I wouldn't push the old chassis much harder
Old Jul 6, 2007 | 06:56 AM
RAMRODD's Avatar
I pulled a 105,000 Semi that broke down during harvest last year 12 miles. I Pulled him threw the elevator so he could get unloaded
When I haul cattle I am in the 30-35,000 pound range When I haul grain I can get up to 42,000.
Old Jul 6, 2007 | 07:37 AM
Gear Jammer's Avatar
dang sounds like some of you guys should invest in a semi!
Old Jul 6, 2007 | 08:24 AM
TxDiesel007's Avatar
about 30,400 lbs
is the most that ive grossed with pictoral proof... now that i think about it the closest thing to that would be a 32 foot goose with a backhoe on it.... Other than that check out my gallery for some loads... Mind u this is without factory overloads... (wont be doin that again anytime soon)
Rick
Old Jul 6, 2007 | 08:37 AM
DodgeCowboy's Avatar
DTR's Cow Boss
I usally am between 26k-30k when hauling cattle that and if iam hauling hat its usally only 6ton on the trailer
