Gooseneck to 5th wheel adapter
Does anyone know which manufacturers state that you can use a 5th wheel to gooseneck adapter on a their camper without tearing up the pin box? I'm looking at getting a camper but don't want a 5th wheel hitch. This isn't something that's an option as I'll buy a tag trailer instead. I know some manufacturers definately say not to use them but others say it's alright.
Thanks for the help.
I would check whith the trailer mfg you have in mind, with that said I have a neighbor that has had a converted goose on three trailers, Fleetwood,Nu-Way, and a Hitchhiker. Each trailer has went to Alaska each year of use with no problems. I strongly believe that it would be wise to consult with the mfg. There are some factory made convertors that state no problems. I have seen some mess up the pin box but it was on the extended pins. Goodluck,,,Rick
http://www.hitchsolutions.com/ranchhitch.html and here is another one http://trailersnhitches.com/putnam/lockloadapp.htm Goodluck,,,Rick
http://www.popuphitch.com/rv1.htm THis is the one my neighbor uses. Goodluck,,Rick
my dad has one on his trailer, he pulls it with a ford 1.5 ton with a CAT motor with gobbs of power and not so soft suspension....has held up nice for about 5 years now, I believe it is manufactured by bulldog, it is in NV and I am in WA so sorry if the manufacture is wrong, but it works good for him.
GREG
GREG
Originally posted by kandgo
IThere are some factory made convertors that state no problems. I have seen some mess up the pin box but it was on the extended pins.
Some are lucky using these gooseneck adapters and haven't had a problem yet. Others aren't as fortunate and have suffered frame damage. If you're thinking of doing it, why not e-mail or call the technical support or engineering group of your 5th wheel manufacturer and get their opinion, especially if you're going to expect them to warrant your RV.
Rusty
I would check whith the trailer mfg you have in mind, with that said I have a neighbor that has had a converted goose on three trailers, Fleetwood,Nu-Way, and a Hitchhiker. Each trailer has went to Alaska each year of use with no problems. I strongly believe that it would be wise to consult with the mfg. There are some factory made convertors that state no problems. I have seen some mess up the pin box but it was on the extended pins. Goodluck,,,Rick {{{{{ When you quote someone qoute the whole statement, not just part of it}}} If you read the whole statement I suggested to consult with the mfg twice. Goodluck,,Rick
Originally posted by RustyJC
And if I could point you to individuals whose 5th wheels have suffered structural damage (failure of pin box to frame welds) when equipped with straight (vertical) Leland Engineering pin boxes, would that make any difference?
Rusty
Rusty
My response was directed to your allegation that only extended pin boxes are subject to failure when used with gooseneck adapters and that straight ones were immune. That's what I quoted, and that's what I responded to.
Rusty
Rusty
I don't have any trailer/camper make in mind currently. I was interested in knowing which if any say it's alright to use the adapter because that is the brand I will go look at. I figure (note I say I) that any manufacturer that will state it acceptable to use an adapter must be a fairly reputable company that knows the limits of their products and have tested them to back their statement up. Sort of like Airstream is (or was a couple years ago) the ONLY manufacturer that did actual crash testing of a camper. The was from a National Highway Traffic Safety testing facility that I toured. With most campers having leaky roofs and windows a common problem I don't want a ripped out pin box to be a problem for me.
Thanks,
Rob
Thanks,
Rob
Rusty
Rusty
I...seem to pick apart some statements on here. I...have never seen...one rip up or break any welds. I would...put a goose adapter on...then I would go.
