Decent hitch for trailer hauling?
Old Dec 2, 2007 | 11:31 PM
Blue6.7QC's Avatar
Not trying to hijack the thread but can you get a slider hitch for the B&W, I have the GN and may want to get a 5er in the future. Thanks
Jeff
Old Dec 3, 2007 | 03:26 PM
Hensley Ron's Avatar
I'm a site sponsor. We sell 5th wheel hitches (TrailerSaver). Not here to sell, but another option is a 5th wheel to gooseneck adaptor. We make one with an air-ride system. Several manufacturers make the straight "tube" for the adaptor. They work quite well and clear up your truck bed. You just have to install the ball. That usually runs $200 to $300. B&W makes a turnover ball that's really cool.
Ron Estrada
www.trailersaver.com
Old Dec 3, 2007 | 03:28 PM
ccoop769's Avatar
Ron Estrada
If you wanna spend the extra cash, get the air ride this guy sells for a 5ver. Thats like best of the best!!!!!!!!!!!!!
Old Dec 4, 2007 | 02:12 AM
Vinceg99's Avatar
I was looking at the air-ride 5ver they sell and what turned me off was the price tag! $2500 bucks is A LOT of cash! May be the best but $2500 for just a hitch is a lot of money!
Old Dec 4, 2007 | 10:32 AM
Yogiyo's Avatar
I have and AirSafe 5th wheel and am very happy with it. I is rated for 25K, fits in standard Reese rails pull four pins and it is out. The standard Binkley-Holland Commercial Anvil comes with the hitch and removes with just two pins. Saves on your truck especially in the oilfield and a great towing experience. I had the reese rails installed and installed the hitch myself.
Old Dec 4, 2007 | 11:57 AM
Vinceg99's Avatar
Where did you get the Airsafe from?
Old Dec 4, 2007 | 11:11 PM
Colo_River_Ram's Avatar
With age comes the cage
B&W http://turnoverball.com/turnover.asp check out the "Accessories" tab
Easy to install, more options for towing.... read sig for in bed harness info and rear wheel tubs if installed....Pics in profile
Old Dec 4, 2007 | 11:23 PM
Texan1983's Avatar
Originally Posted by Truck30Haul
Well if its something I can install myself, I can definitely do it and save the installation charge. Im pretty mechanically minded so it shouldn't be no trouble at all.
yea, i didn't want to pay the hitch store 175 to have it installed, in the end im glad i didn't, but make sure you have a buddy or two help, it's heavy.
Old Dec 4, 2007 | 11:30 PM
The center section is the heavy part...I put a saw hoarse over the hole and used a come-a-long to lift it up..had the thing mtd. by myself in about 2hrs...
Old Dec 5, 2007 | 08:41 AM
By the way, we run a sale in December on the TrailerSaver. $200 off and another $147 off if you want the TruControl brake controller as well. It's the only time of year we run a sale. We also make non air-ride hitches that are more in line with the average hitch cost. They still use the Holland Binkley head that pivots in two directions. Very nice, solidly built hitches.
Old Dec 5, 2007 | 09:11 AM
Yogiyo's Avatar
Bought it directly from Airsafe. Visit their website at at www.airsafehitches.com . I was in Edmonton Alberta at the time and they shipped it from their warehouse in California somewhere. I have been very happy with it. Takes all the chucking out when pulling on rough roads and it has got to be a lot easier on my 5th wheel. Many folks go for the air bag pin box on the fith wheel but why not have an air ride for all the trailers you pull. No twisting of the truck frame or bed is another plus. Just set the air pressure in the bags for the weight you are hauling and go.
Old Dec 5, 2007 | 09:57 AM
Yes, Hensley and AirSafe are the only companies offering full air-ride hitches. Definately an advantage over the pin-box air-bag. The differences are:
AirSafe: goes with the "more air bags the better" theory. 4 air bags.
Hensley TrailerSaver: "Level beam design." The hitch head is mounted to a pivot point in front of and level with the head surface. This transfers both the up/down and fore/aft motion into the air bags. 2 air bags and two shock absorbers.
Prices are similar. Lots of different options.
Old Dec 10, 2007 | 12:28 AM
2500's Avatar
is it true your trucontrol brake controller is better than hydraulic brake controllers?
Old Dec 13, 2007 | 08:33 PM
Rob Mitch's Avatar
I got my B&W and 5th wheel companion at Tweetys. They are just north of San Antion http://www.tweetys.com/index.asp?Pag...&Category=1284
This hitch was an easy install for me. I did have to buy a 4" hole saw bit for $30. (I should have checked Harbor Freight) The rest just hand tools. A torque wrench should be on hand too. Took me a little over two hours by myself. A helper would be good. Instructions were very clear. I installed on a 2007 3500 Dodge too.
Old Dec 14, 2007 | 08:45 AM
I'm convinced that properly adjusted electric trailer brakes with a good brake controller (TruControl is ours) will give you better braking than hydraulic disc brakes. The problem is still the delay in the actuator. The manufacturers are getting better, but it's still an issue. Electric brakes are immediate, though they can be a pain if they're out of adjustment or you have wiring problems.
If you do go hydraulic, I like the Actibrake system sold by Kodiak. The TruControl works well with that system, too.
