-   Towing and Hauling / RV (https://www.dieseltruckresource.com/forums/towing-hauling-rv-95/)
-   -   Brake Controller Problems (https://www.dieseltruckresource.com/forums/towing-hauling-rv-95/brake-controller-problems-148267/)
COVEJEEPSXJ Apr 26, 2007 06:31 AM
First Off I hope I put this in the correct section, If not sorry.
I am having some problems with my Tekonsha Primus brake controller in my 01 2500. After installing the controller and wiring it up, the display shows .c . According to the manual this is supposed to be displayed when a trailer is hooked up and no brakes are applied. However, I don't have a trailer hooked up.
Any Ideas?
Brand new controller never used.
Brand new factory female connection at hitch.
Thanks In Advance.
Bonshawman Apr 26, 2007 08:51 AM
Double check your ground. Mine acts up when the ground gets a bit iffy - this is assuming all other connections sound and made as directed.
Have you hooked the trailer up ? What does it show ? Do the brakes activate ?
With the trailer hooked up, you might also be able to determine that the "brand new factory female connection at hitch" is correctly wired. You have a 2001 truck which is six years old - do you mean the factory wiring was never used, or you have had a Dodge plug newly installed ? I have seen some real butcher jobs.
Sorry couldn't be more helpful.
