Brake Controller Amps goes to high, short somewhere?
Old Oct 20, 2009 | 09:58 AM
jlipskoc's Avatar
My new P3 brake controller has worked great early this summer,
I usually set it at 5-7 depending on what I'm hauling.
The last 2 times, when I hit the brakes the controller goes to full power.
ie. if i have it set on 3, it goes to full 3 amps, there is no proportional braking.
I had to back it down to about 2 to atleast make the trip with some braking.
Is the brake controller shot? Or something wrong in the magnets? Where should I start looking first.
Thanks.
Old Oct 20, 2009 | 10:07 AM
Totallyrad's Avatar
If you've got allot of miles on the trailer the magnets may be worn to the point they're grounding out due to wear.
Old Oct 20, 2009 | 12:04 PM
davidj54's Avatar
If it were a short in the system the controller would sense it and display a message. You haven't changed the boost to 3 have you?
I'd call Tekonsha and ask them. It sounds like it could be a bad controller.
Old Oct 20, 2009 | 01:35 PM
jlipskoc's Avatar
I'm pretty sure I have boost off, will check it tonite.
If it was grounded like you said, it should show up on the screen. I checked the brakes in spring, and everything looked fine.
I'll go into the troubleshooting screen next time I tow to see what voltage and current output is.
I found a .pdf manual on etrailer.com, will go thru it also.
Old Oct 20, 2009 | 04:16 PM
tonycamacho's Avatar
I had my P3 give me the overload fault warning last June, the problem turned out to be a shorted magnet wire. It had worn through and was making contact with the brake shoes. Taped up the wire and no more fault.
Tony
Old Oct 20, 2009 | 04:29 PM
jlipskoc's Avatar
Unfortunately I'm getting no errors or warnings on the screen, it acts like theres nothing wrong.
I just hit the brakes and the meter on the left goes to max, and what ever number i have it set on it goes to that immediately.
Old Oct 20, 2009 | 10:17 PM
jlipskoc's Avatar
Hooked up trailer in the driveway, put a jack under each side of the trailer to spin the tires, each worked ok, and make sure they are engaging, checked the controller, no boost, showed the numbers correctly when manually engaging or just putting the foot on the brake as it puts some braking when stopping. Never could get it to mess up.
I don't know whats going on, guess this weekend, I'll put a load on the trailer and head out. After that, will pull the wheels/drums and check each magnet.
Old Oct 21, 2009 | 07:40 AM
Totallyrad's Avatar
John, do you have a dedicated ground wire or are you grounding through the hitch?
Old Oct 21, 2009 | 09:45 AM
jlipskoc's Avatar
I'm pretty sure its grounded thru the RV 7 pin plug.
I'll check the wiring junction box on the trailer to make sure the ground isn't going bad.
Old Oct 21, 2009 | 07:08 PM
WestTN's Avatar
Check to see if your trailer brake wires cross to the other side through the axles. (If so, they can short out. If they are, it is easy to rewire them and ty-wrap them to the outside of te axle.
Old Nov 30, 2009 | 02:47 PM
jlipskoc's Avatar
I found someone else having the same issue with the P3 while googling.
I called Tekonsha to get a warranty replacement going, apparently its a known issue in the early batches.
I think I'm going back to a Prodigy.
thenrie
Sep 25, 2011 04:47 PM
converteddzlr
Jul 29, 2005 01:35 PM
durasmack
Mar 7, 2005 10:07 PM
royta
37
Dec 19, 2004 02:44 PM
dodgedude361
20
Nov 11, 2004 09:00 AM
