Air Bags on 3500? Pros & Cons
I think the pin or hitch weight is 2635, but the clearance seems to be the same. It does ride better and the rear suspension is working better due to not setting on the over load spring. I only run 50 to 60 psi in the bags.
I've got the Firestones as well.
Empty weight my 3500 rides much nicer than 2500. Loaded its even better. I got mine as a dealer installed option when I bought my truck last year so I'm not sure on the exact price but $200 to $250 sounds about right. I told them why I was buying it and they highly recommended them. They included the chrome full length step bars with the Firestone kit for about $1500 total.
Bottom line: the horrible ride is gone and my kidneys aren't in my back pockets or my throat anymore.
-K
-K
http://mrtruck.net/springs.htm
My experience is the exact opposite of yours. My Ride Rites made my truck ride much worse than before. I wish I had known about this spring before I spent $800 on these friggin bags;
What pressure are you running them at?
Kris
My pinweight is 3240 - - no air bags. I also carry a 50 gallon aux tank/tool box. Total weight hooked and ready to roll is 100 pounds under the GVWR of the truck and I am level. If I loaded more it would exceed the ratings of the truck. So, why air bags? I did have them on my 2500 to carry my slide in that was 4000 pounds, but did not use them on this dually with the camper (before installing the aux tank. Seems if you need air bags on a 3500 you have exceeded the ratings on the truck. What am I missing????
Bob
Bob
I have the Pacbrake air bags, no drilling, they are simple to install, they must be, i did them myself. The key part is the in cab inflation, I can adjust the amount of air in the bags from the drivers seat, as road conditions change I can add or remove air to attain the best ride. When I go and get a load of gravel I just hit the air up switch for a sweet ride home and dump the air when I dump the load. They are a real plus with the camper on, less sway and a smooth ride. Don't know of any downsides.
Product link
Do you have a link to the products your talking about? I’m buying an 06 3500 with G56, is there an engine/ exhaust brake out there for the 6speed manual? Also, to my thinking, the 06 3500 I’m buying sits very high in the rear stock, keeping the nose down under load would help keep it aerodynamic instead of nose up damming air under the truck.Just my theory, but i believe it will work. Also, I’m pulling a 3-4 car wedge trailer.
leisurlee
Sep 18, 2011 06:44 PM
JohnDeereDodge
Sep 18, 2007 11:03 PM
mdq
Jan 16, 2003 04:59 PM
