7k Car Trailer Brake Issue
Old Jun 21, 2009 | 07:22 PM
ramsport59's Avatar
Hey Guys, I have a 2003 Anderson 7k Car Trailer. Tamdom Axles and one is a brake axle.
I'm having issues with my brakes....So the story starts by letting my buddy borrow it and it came back without brakes So I've checked my ground, its ok, I'm getting juice back to the magnets in the wheel. I can slide a peice of metal over the magnets and you feel very little resistance. On both sides. I have the Brake setup in the cab turned all the way up. No difference. Am I looking at a Brake controller issue or a Magnet Issue?
Thoughts? Help!?!?
Thanks
Rick
Old Jun 21, 2009 | 07:37 PM
ramsport59's Avatar
What should the brake controller be putting out?
Truck running, checked the voltage at the truck plug, 12.94volts.
On the Low setting, it stays at the 12.94volts.
Turned up max, It goes to 13.06volts.
That doesnt seem right to me.
What kind of numbers should I have?
Thanks
Rick
Old Jun 21, 2009 | 09:47 PM
rich's Avatar
sounds like a magnet issue
Old Jun 22, 2009 | 09:49 AM
darkvader's Avatar
reading floating voltage(no load) can be inaccurate. dicconnect the wires at the backing plate and hook 12v battery direct(good breakaway batt works). brake application= wiring or controler. no app. = mag. check your grounds again.
Clarl
Old Jun 22, 2009 | 10:24 PM
WestTN's Avatar
Have you checked the mechanical adjustment of the brakes?
Old Jun 22, 2009 | 10:29 PM
ramsport59's Avatar
Clarl
I tried this out today. Magnets are good. So I had my father come over and hook up his truck with the same controller that I have and His truck worked. So we swapped Controllers and its fixxed.
So Now I need to find a good but inexpensive controller.
Thanks Guys!
Rick
Old Jun 24, 2009 | 07:49 AM
davidj54's Avatar
Which controller do you have now?
Prodigy is a good inexpensive controller and the best price I've found is at RVWholesalers.
Old Jun 24, 2009 | 08:47 AM
dodgeguy71's Avatar
I bought a CHEAP controller from something like autozone or tsc for half the price of prodigy, probably less that half. That was three years ago, still works fine to this day as long as goats don't eat through the trailer wires. Hauled tractors, 9k of scrap(7k trailer) and never once had a problem from the controller.
Just depends on what you call cheap compared to what I call cheap.
jimbo486
Nov 3, 2009 01:01 AM
KenC
Jul 11, 2009 02:02 PM
Bad Ramer Jamer
Jul 22, 2008 10:00 PM
dieselbeef
Mar 22, 2008 08:28 PM
Fronty Owner
Mar 13, 2005 11:57 AM
