6 pin trailer plug not working
Old Jun 27, 2010 | 04:49 PM
darkvader's Avatar
Can not get my 6 pin trailer to work on 05 duely. I have marker lights(no tail) but no turn sig. If I turn off tail lights I have turn sig. Works on 95 ford and 92 dodge. what am I missing. Have good cord ground and have used separate hard ground.
Clark
Old Jun 28, 2010 | 08:26 AM
TonyB's Avatar
Sounds like the TIPM needs to be reset. Unfortunately, only the dealer can, unless you know someone with a start scan tool.
Tony
Old Jun 28, 2010 | 09:05 AM
carl48's Avatar
after you get it reset you need to build a isolation box. if you need a schematic pm me
Old Jun 29, 2010 | 09:33 AM
darkvader's Avatar
pm sent carl48. Thanks
Clark
Old Jul 9, 2010 | 09:34 AM
darkvader's Avatar
been away for a bit. I got both pm's carl, thanks
Clark
Old Jul 10, 2010 | 08:38 PM
d zul's Avatar
Hey carl48 whats this isolation box your talking about. Replaced my tipm a few months ago, and if this helps from loosing another I'm all for it.
Old Jul 11, 2010 | 09:21 PM
Brad5502's Avatar
I installed one of these "Modulite HD power circuits" using the $10 wiring kit at this link:
http://www.drawtite.com/modulite1.html
Haven't had any problems with any of the three trailers I tow after I installed it. Basically it sends a stronger signal to your trailer lights.
Old Jul 11, 2010 | 10:18 PM
RTillery's Avatar
I did the Modulite mod too. It is a shame the dealers want hundreds of dollars to fix something that is so cheap, good, and the way the factory should have done it. Mine is working fine.
When they start building stuff that is reliable, simple, economical, and easy to fix, I will feel America is starting to make a comeback.
Sleigher
May 4, 2017 02:12 PM
klx300guy8
23
Feb 20, 2008 01:53 PM
440forPOWER
May 3, 2006 10:31 PM
SkyHarborCowboy
Oct 12, 2005 06:01 PM
gerryz
Oct 3, 2003 11:28 PM
