28' enclosed trailer capacity
jj3500: Now, with the Homeland Security issue, it can be a bit more daunting. If you are going to haul above 26,000, OR YOU HAVE A TRAILER WHICH IS RATED OVER 10,000#, you will need a CDL A. Check out the New York state driver regs for confirmation (assume the DMV has a website via search engine). There will be a written exam and a road test (I got my CDL A in the mid-1970's, so that was a loong time ago....). On the CDL A there are classifications, such as haz mat (requires background check), and some others. You would need to take the road test in a vehicle meeting the requirements (and all of its equipment, etc. should be up-to-par) - as far as finding one to practice with or borrow for the test....guess you need to find a friend or someone who can help you out. I am not sure what they make you now do on the road test, but part of it was the truck/trailer pre-inspection (walk around), and of course driving and parking. There might also be a CDL handbook available from your DMV, and additional info available on the Federal Motor Carrier Administration website. Good luck if you go that route !
For what its worth, I moved a three bedroom two bath two car garage home (1250 sq ft living space) in a 20' enclosed trailer from Yuma, Az to Dallas, Ga with no problems. You will have to learn to pack efficiently and use ALL available space.
New York has no restriction on trailer GVW as long as total weight is not over 26000.
The following clears up the regulations for NY - The class D is the regular drivers license.
New York State New York State New York State
Department of Motor Vehicles
The Elimination of the Non-CDL Class C License
homeon-line transactionsFAQssite mapespañolfind answerscontact or visit search the site
Under a NYS law that took effect on July 26, 2005, the DMV will eliminate the Non-CDL Class C license. In addition, the gross vehicle weight rating and gross vehicle combination weight rating of vehicles that a driver can operate with a Class D license has increased.
The Non-CDL Class C license will be eliminated after the DMV changes the driver license system and can apply the different endorsements and restrictions of Non-CDL Class C licenses to Class D licenses. When the changes are made, drivers who have Non-CDL class C licenses will receive Class D licenses with any required endorsements and restrictions. These drivers will receive the Class D licenses when they renew their driver licenses.
Drivers who have Class D licenses do not need to make any change to their class of driver license.
Until the DMV can make the changes, the DMV will continue to issue Non-CDL Class C licenses to drivers who must have endorsements and restrictions that are not yet available for the Class D license.
A driver who renews a Non-CDL class C license on or after July 26, 2005 can apply for a refund of the difference between the renewal fee for the Non-CDL Class C license and the renewal fee for a Class D Driver license. Use form MV-215 (Request for Refund) to apply for the refund.
A driver license amendment transaction processed on or after July 26, 2005 that results in the issuance of a Non-CDL Class C license will be processed at no fee.
Changes that Affect Drivers
Listed below are the changes that result from the law and affect NYS drivers.
Remember that:
* There is no need to contact the DMV or to apply for any change of the class of your license for the changes to take effect.
* No driver license restrictions or endorsement other than those listed below are affected.
Changes for Drivers with Current Class D Licenses. A driver with a Class D license can now operate a passenger vehicle, a limited use automobile, or:
* A truck with a gross vehicle weight rating (GVWR) of 26,000 lbs. or less. (Before, a Class D driver could only operate a vehicle with a GVWR of 18,000 lbs. or less.), and
* A truck with a GVWR of 26,000 lbs. or less that tows another vehicle, and the other vehicle has a GVWR of 10,000 lbs. or less, and
* A truck with a GVWR of 26,000 lbs. or less that tows another vehicle that has a GVWR of more than 10,000 lbs., but the gross combined weight rating (GCWR) of the two vehicles together must be 26,000 lbs. or less.
A driver with a Class D license can now operate a personal use vehicle (for example a rental vehicle or a recreational vehicle or RV) with a gross vehicle weight rating (GVWR) of 26,000 lbs. or less that tows another vehicle that has a GVWR of 10,000 lbs. or more, but the gross combined weight rating (GCWR) of the two vehicles together must be 26,000 lbs. or less.
Note: The requirement for an "R" endorsement (Class D or Class E license) to operate a recreational vehicle with a GVWR of 26,001 lbs. or more remains in effect.
Changes for Drivers with Current Non-CDL Class C Licenses or Specific CDL Licenses. If you have a Non-CDL Class C license or a CDL Class C license with a "W" restriction that restricted you to operate vehicles with a GVWR of 18,000 lbs. or less, the restriction is no longer in effect.
If you have a CDL Class A license, or a Non-CDL Class C license with an "F" endorsement, that has a "02" restriction (vehicles with a GVWR of 18,000 lbs. or less), the restriction is now the same as a "01" restriction (no vehicle with a GVWR of more than 26,000 lbs.).
For more information, read form MV-14IN (Elimination of the Non-CDL C License Class)
| Home Page | Site Map | Driver License | Registration & Title | FAQs | Vehicle Safety | Contact Us |
| DMV Forms & Publications | Custom Plates | DMV Records | Traffic Safety | News |
| Find Answers | DMV Services | Privacy and Security | Driver's Manual |
Copyright © 2006, the New York State Department of Motor Vehicles. All rights are reserved
Remember that:
benderbrew
08-12-2003 11:33 AM
