2006 Brake Controller plug?
Old Sep 3, 2006 | 02:02 PM
mic646's Avatar
I just picked up my new 2006 2500 last night. This morning I was going to plug in the trailer brake controller but I can’t find the blue connector under the dash. I looked and looked till I got a kink in my neck.
Came with the trailer tow package and had the adapter in the glove box. The truck does have the seven plug wired up in the back.
Anyone know where the darn thing is hidden under the dash?
Old Sep 3, 2006 | 02:43 PM
spitfire9137's Avatar
Its up in there somewhere close to the driver side of the dash. THey used to be clipped on the connector under there that all the dash wires hook too.
Old Sep 3, 2006 | 03:03 PM
MedicShawn's Avatar
On mine it was really hard to find it was clipped behind some other wires and boxes I believe mine was close to the outside of the truck (drivers side), and pretty far up towards the front of the truck/hood. I looked for a good 30 miutes to an hour before I found it.
Old Sep 3, 2006 | 03:20 PM
doznfire's Avatar
Look by the emergency brake bracket.I think it is white.Should be on the left side of the bracket.
Old Sep 3, 2006 | 09:28 PM
mic646's Avatar
I did find a blue connector that is not hooked to anything that has 4 wires to it. The plug is about half the size of the plug that was in the glove box to use.
I plan on calling the dealer as soon as they are open next week.
Old Sep 3, 2006 | 10:23 PM
Smokeman's Avatar
On my 06 it is just to the left of the main harness on the drivers side under the dash. Look under the park brake. Easy to get to and obvious to see. Yours must be different for some reason.
Old Sep 4, 2006 | 01:06 PM
Weg's Avatar
Weg
From the many that I have done. (I install brake controllers all the time at the RV shop I work for). Some of them are easy to see, others are hidden up behind the big bundle of wires going into the box where they use to be mounted on the 97-02 trucks. Its there just look and even sometimes you have to just feel up there and you'll find it.
Old Sep 4, 2006 | 01:51 PM
tiimmer's Avatar
I have an 06 2500, mine is above the parking brake, easy to find.
Old Sep 4, 2006 | 08:39 PM
mic646's Avatar
Found it.
It was taped above the wiring harness block out of sight.
Thanks for the replies.
cszymesko
Apr 13, 2006 02:27 PM
Staceydude
Mar 7, 2006 11:04 PM
terryKS
Oct 5, 2005 12:23 PM
KTM rider
May 25, 2005 06:37 PM
belfert
Mar 15, 2004 04:57 PM
