1500 mile RVing trip complete, some notes...
A couple of side notes, it has A LOT of power and tows great, but it seems that when I need to pull the trailer up a 4x4 to block the trailer up it seems to take a lot of throttle. I wanted to back up a hill (which was steep) and it was taking everything the truck had, I ended up putting it in 4Low.
I understand your point, but you're seriously telling me you'd go on a 500 mile trip with your RPM's up that high? The noise alone would drive me crazy.. let alone the seriously degraded gas mileage. Are you running stock? I've heard the new 5.9's 2003+ can run 1300-1400 no problem as long as kept stock...
when you say your EGT's go right to 1200, are you pulling grade? fighting head winds?
Oh, and yes, the fuel mileage sucked... 8mpg to the coast and 12 back - lots of long hills and headwinds on the way to the coast.
My egt's went to 1200 on flat surface no winds. On the hills I would have to drop it in 2nd to get the rpms up to 2500 to keep the egt's less than 1300. I really don't like to see it run that hot for very long.
I just started another thread about what I can do to offset my tires and 3.73 ratio with some power.
That's exactly what I did - we did a 1400 mile trip to the Oregon coast over the 4th. It was a bit noisy, but not really bad - with my gearing and tires, 2200 rpm seems to be the sweet spot. I am totally stock for now but will be ordering a smarty jr in a while.
where I think I'm in real need is an exhaust brake... some of this hills here in AZ, are real hairy at times, and even my light load I am not comfortable needing to ride the trailer brakes or the truck brakes too long...
yeah, I tow a little lighter load @7k, and on the flats I barely notice the rig behind me and am comfortable in OD with T/H enabled.. the place I know where I'm potentially getting into high EGT's (no guages!) is in the hills and my truck insists on lugging at 50mph in OD... I usually have to kickdown the pedal to get it to downshift into 3rd and it will stick there... a little annoying... but it works..
on a recent trip to colorado, towing in the rockies, I was doing 2nd gear in T/H mode down some of those hills, running 40mph.... poor 5.9 screaming at me close to 2600/2700 rpms.... couldn't imagine towing 10k behind me at all without an E-brake..
I was talking with a few friends this past weekend while we were camping (kind of) and we all agreed a T/H with out the OD would be nice because of the shift points.
Why would you have the stock OD off button, with standard shift points?
Welcome to the world of emmisions. They don't want it to smoke so we get no fueling until boost. The tranny is programmed to always try to get to the next gear to attempt to give fuel mileage. It's a shame but thank goodness there is an aftermarket.
Just got back from 1500+mile trip through central Northern Wa.,pulling 12k # fiver on US 97 via Crater Lake, Ore. UP and Down hill all the way through the Cascades. Crossing the Columbia on US 97 is a good pull all the way North. Used to be a manual tranny fan-But I am slowly being converted to liking the(stay together please) 48RE and the TOW HAUL. LOVE the Cummins-ave.12+ mpg(by hand) with the smarty jr. I am easy on the equipment/no lugging etc...
just my.02 though---Joe
BroncoHound
06-30-2008 07:11 AM
