-   TNDTR #34 (https://www.dieseltruckresource.com/forums/tndtr-34-152/)
-   -   upcoming pulls? (https://www.dieseltruckresource.com/forums/tndtr-34-152/upcoming-pulls-205238/)
zcb6915 May 18, 2008 02:24 PM
upcoming pulls?
anybody know of any upcoming pulls thatll be worth going too?
dodgeguy71 May 19, 2008 04:52 PM
there all worth going to. [guitar] May 31 over in Campbellsville off hwy 166 between Pulaski and Mt. Pleasant. Not sure what time it starts, usually around noon with antique tractors and runs until late......but don't quote me on that for this year. Also one in Hazel Green(?) on the 20-21st of June. Not sure where that is, just saw the ad for it at the Fayetteville pull saturday. You can also check the middle Tn tractor puller assosiation web site and it has the them listed.
dodgeguy71 May 19, 2008 04:54 PM
http://www.midtnpullers.com/
there ya go....
deereguy07 May 19, 2008 11:02 PM
Like dodgeguy said there is the one in Campbellsville I'll have to check on the time. Hazel Green is a real good pull to go to. This will be the 3rd year of having them after they started back up having them there. Hazel Green is about 20-25 min south of Fayetteville on the side of 231/431 jus across the state line. I'll be at both of them.
zcb6915 May 22, 2008 10:37 PM
thanks for the info guys
KVD May 24, 2008 03:43 PM
Hazel green is always good cause the track is very tacky, all in thanks to that good ol alabama red clay.
JSPulliam21 Jun 22, 2008 07:28 PM
There is a local pull in Springfield this Friday night. It is always a good pull, and anybody can pull. If you want to pull BE THERE NO LATER THAN 5:00 pm to weigh in. Pull starts at 7:00 pm.
Click HERE
Friday, June 27, 2008 7:00P.M.
Ticket Prices: Ages 5+ $10, Under 5 FREE
1. Start time is 7:00 p.m. Must be registered by 6:30 p.m.
2. Trucks must meet street legal requirements. No modifications to suspension or external weight bracket.
(Lift kits are acceptable)
3. All trucks must be driven in gate. If they are hauled in, you WILL go into unlimited class. No questions asked.
4. All trucks must be one-ton or smaller in capacity.
5. No propane or nitrous
6. No trucks equipped with kill switches.
7. Hitch height must not exceed 26".
8. Exhaust must extend behind cab and exit through stacks in the bed or in the OEM location. The Unlimited Class
exhaust may exit throught the hood.
9. All weights and loose articles must be secured! No weight brackets on front of truck.
All extra weights must be secured in bed.
10. Current license and registration required and WILL be checked.
11. Weight Classes:
6,200 lb. gas maximum weight
7,200 lb. gas maximum weight
Stock Diesel
o
This must be a completely Stock Truck!
o
No programmers or chips allowed
o
Must have stock exhaust and intake
o
8,500 lb. weight limit
o
NO aftermarket gauges
7,500 lb. diesel maximum weight
o
Must have a stock Turbo
o
Must have at least 1" on travel in the rear
o
No water injection
o
Reciever style hitch required
8,500 lb. diesel maximum weight
o
o
o
No water injection
o
10,500 lb. diesel maximumweight
o
Must have stock Turbo
o
Must have atleast 1" on travel in the rear
o
No water injection
o
Unlimited Diesel
o Truck must weigh less than 8500 Lbs.
o No Nitrous or Propane
o Hanging weights accepted
o Water injection accepted
12. Must have DOT approved tires. NO cut tires.
13. Puller must provide a 1" or larger clevis.
14. Age requirements:
15 years or younger MUST have written parent's consent and adult accompaniment.
16-17 years MUST have written parent's consent.
18 and over - driver assumes full liability.
15. ALL participants MUST wear seat belt.
16. $20 hook fee (per hook).
17. 80% payback per class (except Unlimited Class)
1st, 2nd, and 3rd place will be paid.
Unlimited Class pays -
$125.00 for 1st place
$75.00 for 2nd place
18. All trucks in Unlimited Class will pull in a single class together.
19. Trucks will be inspected at gate and weighed and classed accordingly.
20. Only 1 person per truck when pulling, except if under 15.
21. Any announcements or rules made/changed the day of the event, if needed, supersede these rules.
22. Puller will be disqualified if management is suspicious of puller being under the influence of drugs or alcohol.
23. Truck inspections, before or after the pull, that find violations to the following rules of their Pull Class will result in an
immediate disqualification of truck and driver; all registration fees and prize money will be forfeited.
24. Puller will have 2 chances to pass the 25 foot marker. After passing the 25 foot marker, or after second attempt,
distance pulled will be the recorded distance.
NTPA Truck and Tractor Pull
Saturday, June 28, 2008 7:00 PM
Ticket Prices: Adults $15, Students $10, Under 5 FREE
deereguy07 Jun 22, 2008 10:45 PM
Goin to try to make it to this one hopefully. Not sure rather we'll bring a friend of mines truck or not to pull.
There is a pull in Sparta Sat night at 7:00. It is a Mid-Tenn association points pull. Should be a good one to go to. As of right now we will be there pulling for sure. Don't know any directions to where its at yet. I'll try to get those up on here soon.
JSPulliam21 Jun 27, 2008 05:54 AM
Tonight!!!
dodge.girl Jun 27, 2008 10:01 AM
I was told there was a bone stock diesel class on saturday night, but by the looks of it it's tonight, right? will there be any diesel's saturday night?
JSPulliam21 Jun 28, 2008 12:35 AM
No trucks, like tonight.
deereguy07 Jun 28, 2008 06:25 PM
How was the pull? I didn't make it up there like planned.
