Same old answers again
I know I can find most of the things I need to know in the search, But I have a problem at times getting info. Sometimes I get a message that says if I understand right , its to short to search for. wish I could remember what it was last time when it happened. How do i get around this?
Thats it!! I think I remember seeing the wildcard thing. Thanks a bunch.
BTY Shovel head, it was the stator on the HD, it finally smoked so they replaced both stator and regulator. Really, Im not incident prone
I have not changed the minimum amount of characters in search. The minimum is still 3 so you wouldn't need a wildcard unless you were doing a two character search. The only change I've made is that the system will shut off searching when a load limit is reached, and turn it back on when the system goes back under that load limit.
It seems to be Harley's "Lift Pump".
Dodgezilla
Nov 6, 2011 04:13 AM
J Lent
60
Nov 3, 2009 09:14 PM
dslpwr81
16
Jan 9, 2009 05:22 PM
chariotdriver
Oct 18, 2008 10:50 PM
