Cant view pictures in sticky
I noticed what looks like diesel on the side of the block beneath the lift pump.
decided to go through the sticky to make the job easy as possible. for some reason I cant view the pictures... just get a small box with an x in it. I have tried right clicking and selecting "view picture" still nothing... Is there a setting on my windows box that is out of whack? tks, rjm |
Yep, knowing which sticky you are looking at would help out to pinpoint the problem.
this is the url. i can view the pics in wannadiesel's link but not this one.
https://www.dieseltruckresource.com/...n&onlynewfaq=1 tks, rjm |
Originally Posted by superdodge
(Post 1494098)
I'll have to see if Monty can fix that.
the image pointers are different in the two files. if you right click the first image in the file that works, you get https://www.dieseltruckresource.com/...rientation.jpg
if you right click on the first image box with the x in it, you get https://www.dieseltruckresource.com/...rientation.jpg I suspect it is the difference between the /544 folder and the /500 folder that is the problem. if the image is stored in the same web folder, then the two different threads that point to the image should point to the same place i think.... tks, rjm |
Yep. The photos were moved to make more space for more of BC847's excellent articles. I fixed the thread but I don't have access to the tech facts editing.
