truck just died
Old Apr 2, 2007 | 09:59 PM
Syndicate's Avatar
truck just died
I was driving through a local school zone. Just as i was about to take a turn the truck just died. It simply shut off. I stopped put it in park and tried to start it. I then heard a spashing sound and could smell fuel. Opened my door and got out to see fuel dripping all over the place. There is diesel everywhere. From the valve cover to the tailgate. The majority of the leak seams to be somewhere around the area of the fuel filter. The filter was changed approx 4000 kms ago. I checked the drain valve and it was close. It didnt seam to be the filter cap or or ring. Has anyone had a fuel line go? I have not modded the fuel system at all yet. Anyone got any guesses? Its already at the dealer so I should know more tomorrow. I hope the new service manager is ok. Anyone got any guess as to how all of a sudden there can be a fairly major fuel leak? I would have thought a fuel leak would have caused some stumbling and then caused the truck to die but not in this case. It actualy shut off smoother that when kill it with the key.Would a fuel leak between the tank and CP3 do any damage to the CP3?
Old Apr 2, 2007 | 10:48 PM
FMB's Avatar
FMB
Originally Posted by Syndicate
The filter was changed approx 4000 kms ago. I checked the drain valve and it was close. ...I would have thought a fuel leak would have caused some stumbling and then caused the truck to die but not in this case. ...Would a fuel leak between the tank and CP3 do any damage to the CP3?
I wonder if the filter lid was torqued down a bit too much causing the filter housing to crack, leak, then finally let loose. When it let loose, no pressure or fuel for the CP3. Damage to the CP3 would be dependant on how long it was starved before it quit.
On the other hand, did you happen to check your oil level?
Old Apr 2, 2007 | 10:59 PM
wreedCTD's Avatar
keep us posted.
Old Apr 2, 2007 | 11:07 PM
Syndicate's Avatar
No I didnt check the oil. I actualy changed it 2 days ago. I have already had a couple injectors go. This leak is all diesel and its spraying upward in the engine bay with just they key on and the truck wont start. Nothing at all like when my injectors went south.As far as the filter cap. it looked fine from what i could see on the side of the road.
Old Apr 2, 2007 | 11:09 PM
wreedCTD's Avatar
how many miles and did you have any mods when the injectors went out?
Old Apr 2, 2007 | 11:15 PM
Syndicate's Avatar
truck has 73 000 kms and has had the Quad box since about 25 000 Kms. Injectors were honed long before I had them go bad. I had them replaced and had the tips swapped to the new bodies. Mine didnt crack they were leaking up towards the top from somewhere the tips were fine. They were fixed about 5 months ago and have been trouble free since.
Old Apr 2, 2007 | 11:16 PM
wreedCTD's Avatar
what do you mean when you say honed?
so you have only replcaed them once?
Old Apr 2, 2007 | 11:19 PM
Syndicate's Avatar
They were honed at DDP to flow more fuel. Do a search and youll find lots of reading. They tips are the ones that came in the truck. I think 3 of the injector bodies have been replaced but the tips are all original still.
Old Apr 3, 2007 | 11:50 AM
Syndicate's Avatar
truck is being looked at right now.
Old Apr 3, 2007 | 03:29 PM
Syndicate's Avatar
fuel line coupler blew. Part will be in first thing tomorrow. I think it blew where the line goes from hard to soft under the drivers seat. Im off to go buy lottery tickets. I figure Im suck a lucky guy and its 38 million why not. Ill buy em on my way to the dealership in the morning.
Old Apr 3, 2007 | 03:39 PM
wreedCTD's Avatar
did it loose all the fuel! that $80 bucks!
Old Apr 3, 2007 | 06:26 PM
Syndicate's Avatar
no only lostmaybe 3-4 gallons
truckdoc27
Jan 15, 2007 11:35 PM
lezmark7
Aug 24, 2006 11:16 PM
Tommy93w350
20
Nov 1, 2005 11:07 PM
drew03
Sep 21, 2005 09:56 AM
dieselman24
Jul 30, 2004 05:10 PM
