Shorted power to VE
Shorted power to VE
Well I managed to short the 12v power wire (dark blue) running to the VE and now I have nothing when I turn the key to on. No gauges, starter, lift pump or anything else on an ignition relay. The only thing that works is the buzzer. What did I fry? Obviously some sort of relay or the ignition switch but my wiring is a mess and I'm no good at electrical stuff anyway
. I would greatly appreciate the help.
Nope, fusible links are filled with magic smoke. Once you let the smoke out, it's gone and they never work again.
The fusible links are all on top of the driver's side fender well. Look for the crispy burned wire, it's the one you fried.
Ok it appears that one of the wires has a small burn spot right where it goes into the connector thing. How in the world do I fix that? It's the orange one on the far left.
The repair method in the manual is to peel off a bit of insulation from the heavy feed wire, slightly upstream of the connector thing. Wrap a new piece of fusible link (of the same gauge) around the bared section and solder it to it. Then cut off the old fusible link and connect the new fusible link to the wire. Carefully wrap your connections.
I would do it a bit differently if it were mine. I would get rid of the connector thing altogether and crimp an eyelet to the end of the heavy feed wire. I would attach the eyelet to a single-stud junction block that I had located and installed close by, on the inner fender. Then I would install all new fusible links, or maybe even weatherproof inline fuses, each with an eyelet on the end, and attach them all to my junction block stud. They would then each attach to their respective fusebox feed wires. Simple and professional looking.
Bad Ramer Jamer
142
Aug 18, 2018 04:24 AM
gerdes15
Feb 25, 2008 03:26 PM
So what would be next in line to fry?
