Will this Turbo Work on My Truck
I have a 1998 12 valve and would like to upgrade the turbo. I found a, 2003-2007.5 Dodge Ram cummins 5.9 Dynomite diesel turbo 61/68 1.0AR. Would I be able to adapt this turbo onto my engine? Or would it be to much trouble. I am trying to cool the towing egts.
Thanks
Thanks
Since I haven't seen any replies in 10 days, I'll give you my two cents. The turbine outlet is larger than on your stock HX-35, so you'll need to do something to adapt it to your downpipe. I see you've got a 4" exhaust, so maybe it'll be pretty simple.
flyingd (08-27-2018)
That 1.0AR exhaust housing may be a bit much...
PM member "nascar" on here and ask him to suggest a turbo that is matched with your mods/needs.
He is also available on dieseltuff.com
James Lucas
139
07-14-2003 10:11 AM
