-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   What single or twins? (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/what-single-twins-330998/)
ron406 Oct 3, 2018 09:04 AM
I have an 01 2500 6 speed with 100 hp injectors, Fass 150 lift pump, banks intake, head studs, edge CTS with hot 6 unlock and 4” turbo back. I haul 10,000 lbs through the summer and am looking to lower egt’s. I bought the truck recently and haven’t towed much with it yet. Should I go with a 62mm or 64mm single or a stocker compound set up? Thanks!
NIOMARVIN83 Nov 12, 2024 07:20 AM
For towing 10,000 lbs, a 64mm single turbo would likely be a good choice for lowering EGTs. It should provide more airflow and keep temperatures down during heavy towing. If you want even better efficiency and response at higher power levels, a compound setup (like a stocker) can give you more power and cooler temps, but it might be a bit more complex to install and maintain.
If you're not looking to push the limits of the truck too much, a 64mm single turbo should work well for now. It gives you good towing capability while keeping things simple.
