What single or twins?
I have an 01 2500 6 speed with 100 hp injectors, Fass 150 lift pump, banks intake, head studs, edge CTS with hot 6 unlock and 4” turbo back. I haul 10,000 lbs through the summer and am looking to lower egt’s. I bought the truck recently and haven’t towed much with it yet. Should I go with a 62mm or 64mm single or a stocker compound set up? Thanks!
For towing 10,000 lbs, a 64mm single turbo would likely be a good choice for lowering EGTs. It should provide more airflow and keep temperatures down during heavy towing. If you want even better efficiency and response at higher power levels, a compound setup (like a stocker) can give you more power and cooler temps, but it might be a bit more complex to install and maintain.
If you're not looking to push the limits of the truck too much, a 64mm single turbo should work well for now. It gives you good towing capability while keeping things simple.
dslpwr81
Aug 9, 2008 12:25 AM
dodgeman5902
Feb 20, 2008 02:27 PM
omaharam
24
Dec 28, 2007 11:32 PM
heykw
14
Dec 9, 2007 01:34 PM
jeeptjstud
Feb 28, 2007 03:08 PM
