what is missing?
Old Oct 11, 2005 | 03:52 PM
cumminsman02's Avatar
Muted User
what is missing?
hey all i looked at my 02 HO motor today to get ready for twins and to my suprise i do not have the extra oil bung that i thought all 24 valvers had. any suggestions? i am pretty sure i am looking in the right place. maybe some pics would be nice of those with the oil bung and those without would be nice!!
thanks in advance!
Old Oct 11, 2005 | 05:31 PM
storx's Avatar
there is an extrea bung ontop of the oil filter assembly...and there is a plug you have to drill and pull out to run the return oil line for the secondary turbo which loacted about 4 inchs from the rear of the engine on the passenger side....
Old Oct 11, 2005 | 05:44 PM
signature600's Avatar
I think he means for the turbo drain!
It should be about 18in back from the front one if I remember right.
Chris
Disclaimer: I don't own a 24v, so take it FWIW
Old Oct 11, 2005 | 07:25 PM
Muted User
thanks fella and i do appreciate it and yes i do mean the return. i built a set of twins for a 12 valver and i knew it had to drill the oil pan and that was a hard process and when i went to the 24 valver i thought they ALL came with the extra oil bung for the return if i ever went twin turbo route. i didn't see an actual bung like the front one, but i did see a plug that appears to have a somewhat of an allen wrench head on it that is at the bottom of the block directly above where the oil pan bolts on that is towards the rear of the motor, is that the one i have to pull? please help as this weekend i had hoped to have it completed. but to repeat myself i thoguht all 24 valvers had the extra bung!!
Old Oct 11, 2005 | 08:47 PM
Not sure...better see if anyone who has one chimes in. If they don't, I'll check out my buddies 02 and see what his has.
You don't, by chance, know what "number" block you have, do you. (Ex. 53, 56)
That might help narrow down why it doesn't have one, if in fact, it doesn't.
Chris
Old Oct 11, 2005 | 09:19 PM
Muted User
maybe some pics from anybody would be nice and better!
Old Oct 11, 2005 | 10:15 PM
ratsun's Avatar
Cant say about a 02 bu my 98 looked like a small freese plug back from the stock drain.
Wish I could help more..
Old Oct 11, 2005 | 10:50 PM
joefarmer's Avatar
You should have one there. ~18" to the rear of the first one along the same plane. It's a freezeplug about 1" down into the hole.
If you look here, it's directly under the coolant line coming from the transmission heat exchanger.
http://www.firepunk.com/gallery/lavo...anning_layout2
You can see where both of them come inside this 53 block in this picture:
brandon.
Old Oct 12, 2005 | 12:41 AM
Muted User
thanks guys and thanks brandon for the pic i was apparently looking for the wrong thing i was looking for an actual bung and didn't even think it would be just a metal plug. thanks guys!!
by the way where do you all get the short 4" rubber hoses to connect the cold pipe to the top turbo? i asked around the local diesel shops and they said they didn't know what i was talking about so i thought i would ask my fellow diesel enthusiasts!!!
thanks again
CrewCab
Apr 23, 2003 08:06 AM
1ST GEN.
Feb 9, 2003 04:57 PM
divekrb
Feb 4, 2003 10:57 PM
Kimrey
Feb 3, 2003 03:00 PM
Got Smoke?
Dec 21, 2002 12:27 PM
