what external wastegate???
i am going to get a wastegate but dont know witch one is best. i am running 40psi and i have a edge jammer ball bearing 58mm turbo. what mm gate do i need? i see a lot of people using 38mm tial wastegates but they have twins? what would be best for my application?
Like you said, the Tial F38seems to pretty popular. Its a great piece and it must work well for so many here to be using it. Personally, I like the Tial V44 because it mounts with a V-band clamp and has no gasket to blow out. I have one of them on my turbo Mitsubishi and its also a great piece. However, the 44 is significantly more expensive ($375 vs. $225) so if I were looking to do a WG on my truck I'd probably go with the F38. The only reason I went with the V44 on my car was that it was part of a ridiculously low priced package deal I got from a local guy that bought the parts and then pulled the plug on the entire project he was going to use them on.
John
John
thats a really good poing the v-band makes it so much nicer. ifyou use a good metal gasket with the 38 youll be good though. look at turbosmart also, they have nice stuff, and may make a smaller wg with a v-band. I would loog in the 38 range and if you can find one v-band go that route, if not stay with the tial 38
ok so when i was on the tial website i was looking at all the information about the w/g and the springs, which one would i need? and hows the install? i do all the work on my truck myself unless its really complicated is this a simple install?
RowJ
Mar 1, 2005 04:50 PM
AK RAM
24
Jan 20, 2005 08:50 PM
KatDiesel
Mar 11, 2004 07:31 AM
