what else needs done
1997 dodge
gasket & seal kit Governor spring kit, 4K RPM Delivery vlaves valve springs, 60# heavy duty vavlve spring retainers, titanium & 10 degree keepers R&R valve springs Retorque head spring throttle 370 marine injectors 5sp tranny duel disc ceramic clutch ALL DONE AT HAISLEYS AFE AIR FILTER between 300 s and 400s turbo (daves diesel told me that) |
Be more specific
as what you want to do with the truck, HP TQ? just what else needs done is wayy to broad.. what do u want this truck for? Tx |
Both horse power and torque would be good might use it for pulling later on.
while not listed im sure a fuel plate has already been added, you seem to be at the point of having to have the pump set up at a shop and put on the flow bench for some serious fuel or get a pdr stoopid pump, and get a bottom turbo and have some twins fabed up. that pump has the ability to push endless amounts of fuel if set up at a shop, tell them (haisley, schied, ect) what you want and they can help custom injectors 800cc fuel pumps compound chargers camshafts pistons headwork its all about how much money you have and what you wanna use the truck for.
