What is the differance: injectors-fuel plate
For my next mod I am going to add a more aggresive fuel plate or more aggesive injectors. The two mods should add about 40hp. My question is; is all hp created equel, or is the hp provided by one of these mods more noticable. Is one more apparent on the bottom end and the other on the top end? I hope you get the idea because I am having a hard time explaining it with my limited knowlage.<br>Thanks<br>tim
Re:What is the differance: injectors-fuel plate
Both give you more fuel. I think the fuel plate would net more but the injectors are nice also. I just felt the biggest difference in the Fuel plate. With the injectors I just got more smoke<br>DM01
the injectors give a broad increase across the power band. the lower fueling level plate can change the fueling on the top end for egts or other areas for whatever reason. a #0 plate will give you full fueling though whatever your pump and injectors can dish out, but your right foot is the controller of egts.<br><br>Tom
Diesel-Dan
11-21-2003 09:16 PM
